Left knee hitting steering wheel
Originally Posted by HUNTERANGEL121
Don't think it would make much of a difference depending on the shoes.
The top of the clutch pedal should be even with the top of the brake pedal, and this can be adjusted so your assumption is false. You do not want to remove all of your free play to achieve this, you want to adjust the master cylinder rod to adjust the pedal height and pick up the added slack with the top out switch and get these balanced in a way that you have not only an even pedal height with brake, but that you are getting as much master stroke as possible with the minimum free play needed to insure your not riding the pressure plate and wearing out your clutch. As the clutch disc wears in any car, you will start to take up free play, so its important that you keep an eye adjustment as you put a lot of miles on the car. If the pedal is so far out in order to maintain any free play at all , then that is an indication that your about out of clutch disc material and be prepared for a replacement sometime in the near future. If you want to feel what a perfectly adjusted clutch pedal feels like in an s2k, drive my car.
I might make a DIY video on this...
