Lights readjustment!
Old Nov 28, 2007 | 07:58 AM
daktruckie99's Avatar
You're high beams are only good for 40 ft? Your adjustments must be all out of wack!
I can easily see 100+ feet with high beams on.
Old Nov 28, 2007 | 08:30 AM
YoZUpZ's Avatar
[QUOTE=daktruckie99,Nov 28 2007, 08:58 AM] You're high beams are only good for 40 ft?
Old Nov 28, 2007 | 09:06 AM
Vik2000's Avatar
lol we sit so low and our headlight angle should face up more.
Old Nov 28, 2007 | 09:33 AM
CKit's Avatar
It helps to have a flashlight to "see" the screw. There is a special hole in the fender / frame that is there to get the correct angle to reach the screw without removing any body parts.
Old Nov 28, 2007 | 10:09 AM
HankookS2K's Avatar
u need a LONG screwdriver
Old Nov 28, 2007 | 10:10 AM
Originally Posted by YoZUpZ,Nov 28 2007, 12:30 PM
He's not talking about his brights... I don't think... I think all s2ks (early ones at least have that cut-off. Your drivers side headlight is set lower than your passenger side headlight, correct? I believe this was done so it wouldn't blind incomming traffic (there was tons of crap going around about HIDs causing night-blindness to oncomming motorists when the s2k came out) so I think they overdid it and made it excessively low...
Well then if he can't see with his low lights, put his brights on! That is what they are for after all you know.
They are all set with the driver side lower. This is built into the bulb/projector housing and comes from BOTH bulbs. This can not be fixed with a height adjustment.
sinistersoups
Aug 12, 2013 12:53 PM
altahina
May 9, 2008 12:07 PM
1FastS2k
Dec 8, 2003 05:05 PM
awWhHDayUm
Dec 17, 2001 11:51 AM
getchastuff
May 3, 2001 05:15 AM
