Long term storage... Up to two yrs
Old Aug 11, 2010 | 07:25 AM
mdawson's Avatar
Default Long term storage... Up to two yrs
Going to be out of the country for up to two years possibly. I followed all the 28 steps from the winter storage guide except I did not do the oil fogger and I did put in fuel stabilizer. Is it absolutely critical to takenout the spark plugs and get some oil in there or is that overkill? Other comments and suggestions welcome.
Old Aug 11, 2010 | 11:43 AM
rob-2's Avatar
I would do it if I was Anal.
After 2 years I believe the fuel, even with a stabilizer will be bad. This would mean a drain.
Old Aug 11, 2010 | 12:18 PM
MasterForce's Avatar
wow two years? i would leave a little gas there almost empty. that way when you come back you can put new fuel and once you started again it will quickly clear the old fuel and use the new fuel.
Old Aug 11, 2010 | 12:51 PM
Conedodger's Avatar
Bad idea. Condensation will cause rust in the tank. Add stabilizer, run for 10 minutes, shut off and top off the tank. It'll start up just fine after two years. Personally, I would add some oil to the cylinders, not that difficult to do.
Old Aug 11, 2010 | 05:43 PM
NA EP3's Avatar
Our tanks are plastic. There shouldn't be a rust issue.
Old Aug 11, 2010 | 05:46 PM
zeroptzero's Avatar
use an upper cylinder lubricant in the fuel tank before you leave. You can find Lucas Upper Cylinder lubricant at most auto stores. Add in about 3-4 ounces, fill up the tank to mix it in, run the car for a bit before the final shut down. Use fuel stabilizer to keep the fuel fresh. The upper cylinder lube will lube parts that come into contact with the air fuel that don't normally get lubed in normal driving. It will leave a lubricant on the cylinder walls, pistons, rings, valves. I use it quite a bit in normal driving so it will work fine in your situation.
I would fill the engine with a high mileage oil, those oils contain esters that help to condition engine seals which would be beneficial in your long storage situation. Most companies make a high mileage oil such as Castrol, Valvoline, Penzoil, Mobil.
Old Aug 12, 2010 | 03:56 AM
Siepel's Avatar
Old Aug 13, 2010 | 07:56 AM
Mistman's Avatar
Make sure that no mice can get into it. I parked mine for 10 months and had a basketball sized mouse nest in the trunk. Pretty unsanitary and frustrating.
Old Aug 13, 2010 | 08:05 AM
unethikl's Avatar
best possible way would be to get someone start and idle the w/ little rev time to time, but if that's not possible, I think you're going the right way. But I wouldn't top off the tank tho.
Old Aug 13, 2010 | 07:57 PM
R3DS2K's Avatar
if your really anal get one of these or similar
http://www.carcapsule.com/
