Low Mileage Maintenance
Old Oct 9, 2008 | 06:27 AM
Suzukaboy's Avatar
Default Low Mileage Maintenance
MY 2005. I change the oil twice a year and I have changed the transmission fluid and rear diff fluid once about 2 years ago. The car has not been tracked.
I notice in the manual that they want brake fluid changed after 3 years. The pollen filter after two and the air filter after 30k miles. I'm thinking about having all of the above done now.
Other than inspections is there other items that I should consider.. stuff that is not dependent on mileage? Like an alignment? I don't see any abnormal tire wear and the car doesn't pull or anything and I'm thinking I should just leave it alone.
Old Oct 9, 2008 | 06:35 AM
vtec9's Avatar
I would just do the things you mentioned.. everything else should be A-OK.
Old Oct 9, 2008 | 06:56 AM
roflitzjinno's Avatar
routine maintenance is always good. its usually based on how long or how many miles have been put on the fluid.
Old Oct 9, 2008 | 12:08 PM
rich85tpi's Avatar
I usually have an alignment done when I have new tires installed.
You might want to use some of that Shitzu grease on the rubber seals of the soft top.
Old Oct 9, 2008 | 12:41 PM
common reactor's Avatar
Sounds fine...take care of the car and it will take care of you.
Old Oct 9, 2008 | 12:55 PM
Suzukaboy's Avatar
Post
Forgot about that. Good idea.
I had to look it up and it's actually Shin-Etsu but Shitzu I'll remember.
kuniko
Apr 7, 2008 02:16 PM
emerlin
Oct 9, 2007 11:49 AM
r_duff
Aug 17, 2004 07:03 AM
Ajjra
Nov 17, 2003 08:07 AM
allkingz
Jul 17, 2003 12:37 PM
