Lowered Car, now Vibration
Originally Posted by negcamber,Jul 16 2007, 11:09 AM
Your inner CVs are causing the vibration. You can solve by either getting half-shaft spacers (costs $) or by swapping the inner CVs from drivers side to passenger & vis versa (free but takes a little more time).
In a nutshell, the CVs get a wear spot and when you lower a car with a few miles, the bearing in the CV moves just a bit out of the wear spot. The bearing then trammels back and forth from the old wear spot to its new resting spot.
HondaS, swapping the cups repositions the spiders so they run on a fresh surface. The spacers do the same thing, so if they were free ...
Plokivos, you're right; The spacers are purdy.
The slit spacers are also easier to install, and as far as I know there are no downsides. I'll see if I can get Billman to chime in and explain why swapping the cups presents a new wear surface to the spiders. No need to guess when we have someone here who actually knows this stuff inside and out.
JDM-S2K19, why on earth would you do both?
HondaS, I don't know if a DIY has been posted, but removing and replacing the cups is covered in the shop manual. If you're working on the car yourself, the shop manual is worth having.
I'll PM Billman and see if he'll chime in on this. He might even see something in the symtpoms that point to something other than the inner CV joints (though I doubt it, I can't be sure, 'cause Bill really knows these cars way better than anyone else here).
YO, BILLMAN, PM coming your way. We need ya!
The slit spacers are also easier to install, and as far as I know there are no downsides. I'll see if I can get Billman to chime in and explain why swapping the cups presents a new wear surface to the spiders. No need to guess when we have someone here who actually knows this stuff inside and out.JDM-S2K19, why on earth would you do both?
Spacers will be a band aid if the buckets are pitted. I'll bet they were already starting to pit, and the drop amplified it.
Swapping the buckets will result in 100% cure.
After the swap, you'll be using the drive flanks of the buckets that have only been used while the car is in reverse. You'll now have alxe buckets with less than 5 miles on them
AFAIK, there is nothing defective about the CV joints to begin with. From what I understand, the issue derives from normal wear in the CV joint. As long as the engagement point within the joint remains the same, there is no issue (until completely worn out of course). When you lower the car, the engagement surfaces inside the CV joint change and the vibration is related to the transition between the edge of the worn surface and the less or unworn section. Spacers put the relationship between the two halves back to where it was.
chriss2kk
Apr 14, 2012 10:44 AM
