Lowride
Could you lower your car yourself? Ok so this is a NOOB question yes, but for a while my car has been totally stock and all. After saving up, I thought it was time for a change. Also I want to know if it illegal to lower your car. I don't want to lower it too much, maybe like 1-2 inches.
I personally would not know attempt installing lowering springs myself.
I was privy to watch a DIY of Buddy club coilovers and they were fairly simple to install. It was the amount of "muscle" required to turn the crescent wrench and the markings of how far to lower were the key.
as per legality, it matters your local law enforcement's discretion.
1 to 2 inches on an s2000 is quite fine imo
Originally Posted by TheKuz,Nov 2 2004, 10:48 AM
I took my car to a shop to be lowered, and no it is not illegal unless you go very low to the point where it is rubbing.
- also illegal if the body is lower than the rim of the wheel (not the tire)
- not sure how its illegal if you're rubbing?
its your car, if you want to rub all over... like me.
Dut has it right, if your body panels are lower than the lower portion of your rim it is illegal. Also you can do it yourself, the s2k is probally the easiest car to change springs on just be sure to have the right tools and the right amount of muscle to tighten/loosen some of the bolts.
Me and a friend of mine did it ourselves in about 4 hrs. start to finish.If there's a Pep Boys nearby, they have a tool loaner program where you can borrow the spring compressors. BTW, the left rear was a PITA.
ok i just got a set of ESPERLIR springs and my friend is telling me to do it ourself.... but i'm not quite sure if i want to do that...i am scared something might go wrong. for those who have done it before. is it easy to do it? and any tips is welcome....thank you
Khang
