LSD
Old Dec 16, 2007 | 05:32 PM
xxlap1xx's Avatar
Default LSD
Does LSD improve handing of the car?? Does it make it easier to predict when the car will oversteer??
Thanks
Old Dec 16, 2007 | 07:45 PM
pierceman's Avatar
1.5 way or 2 way? the 2 way will push you to oversteer easier when on the gas if that is what you are looking to do. most of the drifters run a 2way for this reason, some racers like it too
What are you trying to get done? A more predictable/create oversteer? or better handling?
tires are the best way to get better handling
Old Dec 16, 2007 | 07:57 PM
pierceman's Avatar
BTW, this should be in under the hood or track talk, try there
Old Dec 16, 2007 | 08:40 PM
afwfjustin's Avatar
If you want to lessen the oversteer, a bigger front sway bar will help tons. I love my Whiteline 30mm front sway
Old Dec 16, 2007 | 08:51 PM
xxlap1xx's Avatar
Im just trying to make grip driving better, if it helps.....
Old Dec 17, 2007 | 05:29 AM
Marin's Avatar
You realize the S2000 has an LSD?
Old Dec 17, 2007 | 06:51 AM
saggy311's Avatar
all S2000 has LSD and LSD allows both rear tires to get grip of the road, instead of your right tire only. so technically you do get better traction.
Old Dec 17, 2007 | 07:14 AM
HankookS2K's Avatar
Originally Posted by saggy311,Dec 17 2007, 08:51 AM
AP2 has LSD and LSD allows both rear tires to get grip of the road, instead of your right tire only. so technically you do get better traction.
all s2000's have lsd
Old Dec 17, 2007 | 07:40 AM
INTJ's Avatar
Old Dec 17, 2007 | 07:44 AM
Vik2000's Avatar
no wonder it's luxury
