Lug Nut Torque Wrench
Old Sep 20, 2004 | 10:41 AM
Sgt Skidmark's Avatar
Default Lug Nut Torque Wrench
Before you flame me, I did run a search but found only the ft/Ib numbers.
I am about to buy a wrench to use removing the lug nuts.
Do I need a 3/8" or a 1/2" wrench ?
any help would be mah-valous dahling.
Old Sep 20, 2004 | 10:48 AM
jedraz's Avatar
Off the top of my head I think it is 85 ft lbs and use a 1/2 torque wrench.
Old Sep 20, 2004 | 11:40 AM
mwy23's Avatar
if your 19mm socket is a 3/8 drive, get a 3/8 torque wrench. if its 1/2 drive, get a 1/2 torque wrench.
Old Sep 20, 2004 | 03:10 PM
Road Rage's Avatar
With the 3/8, make sure your wrench goes high enough - many I have seen are calibrated in inch-pounds, so you need to divide by 12 to get foot-pounds. My 3/8 incher does not go up to 85 lbs.
Old Sep 22, 2004 | 07:51 AM
rjosey8385's Avatar
For my '04 lugs, I use a 1/2" torque wrench with a 3/4" socket and torque to 90 f/p. I believe acceptable torque is from 80-95 on these, but since I AX the car, I do it to 90.
Old Sep 22, 2004 | 08:07 AM
Boston Duce's Avatar
If you can swing it, try to get the click stop type instead of the beam type.
Make sure you reset to "0" when you store it, and don't drop it!
BD
white2k
Jun 11, 2007 02:30 AM
__redruM
May 21, 2007 05:30 PM
jert534
Aug 1, 2006 07:00 PM
samjabori
Apr 7, 2004 08:39 AM
Philly G
Sep 29, 2001 07:44 AM
