Lug nut torque?
Old May 21, 2007 | 09:28 AM
__redruM's Avatar
Default Lug nut torque?
Do you need a torque wrench to change a tire on the S2000? What happens if I don't use one?
Old May 21, 2007 | 09:46 AM
-Q-'s Avatar
-Q-
It is best to have a torque wrench. Otherwise, too tight and you could snap your lugs. Too loose and they may fall off.
A torque wrench comes in handy for working on the car anyway.
Old May 21, 2007 | 09:47 AM
s2kshift9k's Avatar
i would torque them also
Old May 21, 2007 | 09:53 AM
__redruM's Avatar
I has heard that I could warp and/or ruin a brake rotor if I did it by hand. I know I could get the wheel on safely without breaking the studs by hand, but there's no way I could get the torque right by hand.
Old May 21, 2007 | 09:55 AM
Gatsbee13
Guest
Posts: n/a
If you do torque it by hand, torque it to 80lbs (oem spec).
Old May 21, 2007 | 10:01 AM
paulzale's Avatar
I have always hear that over torquing can warp a rotor or snap lugs. I have never seen this happen, however I use a torque wrench unless I do not have one then I will hand tighten (likely overly tight) until I can get home and put the torque wrench on it.
Old May 21, 2007 | 10:04 AM
DeeDubya's Avatar
You know, I've known a few who just have a feel for how tight is right. I would always use a torque wrench on an alloy wheel.
You might: overtighten and not be able to remove a lug nut with the cheezy little wrench if you have a flat on the road, or
you might: undertighten and have a wheel loosen. It will ruin your wheel and is of course dangerous.
and I would never trust the so-called torque extensions that some tire centers use on their impact wrenches. I can testify that these are totally inaccurate.
Old May 21, 2007 | 10:06 AM
__redruM's Avatar
When I say, "by hand" I mean without a torque wrench. So I would have to guess, based on feel. A friend had false antilock brake and traction control engagements along with a pulsing brake petal, that he said went away when the lug nuts were properly torqued. This was on a GM sedan. I was wondering if the S2000 had similar issues.
Old May 21, 2007 | 10:51 AM
blackout's Avatar
This is the first car ive ever used a torque wrench to tighten the lugs on. I cant see how a ballpark of 80-100ft# would be dangerously high. Its usually better tighter than looser.
"thats what she said"
Old May 21, 2007 | 11:14 AM
novatemp03's Avatar
80lbs with a torch wrench, otherwise its just guesswork.
