major tune ups
i might be purchasing a used s2k has 74k for 15k or under. if i do end up getting it is there any major tune ups that i have to do around at this mileage or does it only require basic maintainence.
^^wow that was nice lol
check the owner's manual--it has all the service you'd need at that mileage listed. but if i was buying used and it has that many miles on it i'd change/bleed all the fluids (coolant, clutch, brake, tranny, diff, oil). but if you're buying from a Honda dealer you might not need to change all that. they might have already given the car all the service it needs.
Originally Posted by rocrfella,Oct 18 2007, 04:57 PM
Ask the dealer/seller or Jesus, better yet, ask miss Cleo. We do not know.
Follow the scheduled maintenance and you should be fine. If valves are chattering, you might want to get an adjustment. Consult the S2000 library section for a bunch of info.
get a compression or leakdown test done. that will give u an idea of how the engine life is at on all cylinders. get a new air and oil filter, and the oil and tranny fluid changed with some good synthetics. maybe some new spark plugs...
tony
tony
itguy
Aug 19, 2008 05:18 AM
