Make recommendations..
Old Feb 12, 2008 | 07:22 AM
rnye's Avatar
Default Make recommendations..
So I am doing some service to my car soon to get it "good as new." I'd figured I'd make a thread to poll people on what they use and to get some ideas. Part numbers would help (esp for OEM stuff like filters).
-Oil
-Oil filter
-MTF
-Diff
-Air filter
-Cabin filter
So far this is what I've come up with.
-? (Probably OEM, unsure on part numbers)
-Honda MTF or GM Syncromesh II
-? (Probably OEM, unsure on part numbers).
I won't be doing this for a few weeks, and I could easily just go to Honda and get all the parts/info OEM - but this is phase one of my market research and I want to see if any S2kiers have better (and up to date, not outdated search results) input! Also, is there anything else I should be looking at doing? I've read about Shinetsu grease on here for seals.. LMK. Looking for good ideas/suggestions on preventative maintinence stuff.
Rick
Old Feb 12, 2008 | 07:49 AM
TimesNewRoman's Avatar
I use:
Oil: Mobil 1 full synthetic
Oil Filter: OEM (ordered a six-pack from Majestic Honda)
MTF: Penzoil Synchromesh
Diff Fluid: Mobil 1 full synthetic gear lube
Air Filter: I have a K&N FIPK
Cabin Air Filter: OEM (I don't even know if there is an aftermarket route here)
Old Feb 12, 2008 | 07:58 AM
kamui157's Avatar
Oil: M1 or Castrol Syntec. M1 burns quicker in some engines.
Oil Filter: Honda OEM, PCX filter
MTF: New Honda MTF
Diff Fluid: LE-607
Air Filter: Depending on intake.
Cabin: Only OEM...
Hardtopguy is the only place I know to get LE-607 along with all the other stuff at the same time. Walmart sells sythetic oil, 5qts jug for $21~.
Old Feb 12, 2008 | 08:08 AM
s2kshift9k's Avatar
Oil: Mobile 1 syn.
Oil filter: OEM
MTF: New honda MTF
Diff fluid: Mobile 1 syn.
Air Filter: OEM since my is stock
Cabin: OEM
Old Feb 12, 2008 | 10:13 AM
GT_NFR's Avatar
Originally Posted by TimesNewRoman,Feb 12 2008, 11:49 AM
I use:
I remember reading a whole analysis of why the penzoil synchromesh is not good for the tranny. I use the GM synchromesh friction modified (it makes a big difference but seems to break down quicker).....I think some people think that the penzoil one is just a re branded version of that....its not. But the supposedly the new honda MTF is really good also, thats what I plan on using for the next tranny fluid swap.
Old Feb 12, 2008 | 10:15 AM
GT_NFR's Avatar
Man whats up with all the synthetic....what happened to good'ol conventional? I figure if the oil is going to get dirty anyways might as well change it out every ~3,000 miles.
Old Feb 12, 2008 | 10:59 AM
114_ap2's Avatar
oil: elf 5w-40
oil filter: K&N HP-1004 (i think)
MTF: amsoil or OEM
Diff: motul 80w-90
air filter: k&n part #e-2435 (i have AEM V1)
cabin air filter: OEM part #79831-s2a-003
Old Feb 12, 2008 | 11:15 AM
NoRawkus305's Avatar
oil: Mobil 1 10w30, might be changing to Royal Purple just because I burn alot of oil with Mobil 1. Going to check if it makes a difference.
oil filter: OEM
MTF: Honda MTF
Diff: Mobil 1 gear lube 75w90
air filter: OEM
Old Feb 12, 2008 | 12:45 PM
JimiChanga's Avatar
-Oil: Mobil 1, Amsoil, or Redline(what I use)
-Oil filter: OEM
-MTF: Tried Redline, but didn't like it too much, so new Honda MTF now.
-Diff: LE 607, but plan on upgrading to LE 1605
-Air filter: K&N drop in
-Cabin filter: OEM, doesn't really matter
Old Feb 12, 2008 | 12:52 PM
Sabre's Avatar
