Is it me or the...
Old Nov 19, 2003 | 08:21 AM
  #21
2001_s2000's Avatar
How would you double clutch into first? Never did it. Do you do it in other grears too?
Old Nov 19, 2003 | 09:48 AM
  #22
Intrepid175's Avatar
[QUOTE]Originally posted by Jason B
Old Nov 19, 2003 | 10:22 AM
  #23
xviper's Avatar
Intrepid175, go check your PM. I need your email address before I can send you the vid. The whole email will actually be 4724K big.
Old Nov 19, 2003 | 10:31 AM
  #24
xviper's Avatar
The following comes with this warning:
Make sure that when you begin to downshift into 1st that you are not going faster than what 1st gear can handle or you will mechanically over-rev the engine and ................ KA-BOOM! Know what the max speed of your car is in 1st and do not attempt this at, near or above this speed.
You are in 2nd and are decelerating. When you get to an appropriate speed (as mentioned in my warning), clutch in/gas off, tranny to neutral, clutch back out, blip the throttle aggressively and immediately clutch in, tranny into 1st, release clutch before revs drop too low. If it does drop too low, then you'll have to do a second blip just before the final clutch release. You'll know the revs dropped too low when you jerk like crazy or even chirp the rear tires.
NOTE: I hold no responsibility for any damage incurred as a result of driver error.
Old Nov 19, 2003 | 11:24 AM
  #25
mxt_77's Avatar
[QUOTE]Originally posted by xviper
Old Nov 19, 2003 | 11:57 AM
  #26
xviper's Avatar
[QUOTE]Originally posted by mxt_77 BTW... I'm not sure that double-clutching is really required to make this work, but rev-matching is definitely required, in order to easily get it into 1st gear.
Old Nov 19, 2003 | 01:03 PM
  #27
Old Nov 19, 2003 | 01:11 PM
  #28
xviper's Avatar
Old Nov 19, 2003 | 01:20 PM
  #29
cthree's Avatar
Administrator
Change the clutch fluid. I just did mine and it makes a huge difference esp. shifting to 1st and R.
Old Nov 19, 2003 | 02:01 PM
  #30
AP1ByDesign's Avatar
I try no to shift from 2nd to 1st...
