Megan Test Pipe VS Berk Test Pipe
Old Feb 16, 2006 | 07:09 AM
overlord's Avatar
Default Megan Test Pipe VS Berk Test Pipe
Thinking of getting a test pipe for my car...I am choosing between the 2 and was wondering what other members think is better, performace wise and sound wise.
The Megan pipe is resonated and I believe it will trigger the CEL when installed. On the other hand, the Berk pipe will not trigger the CEL but is not resonated. I have an HKS exhaust and was wondering w/c setup will perform and sound better. I heard that the BERK pipe sounds "so so" on the HKS. Does anyone in here have the Megan pipe on an HKS? What are your thoughts? I do not want that "fart can" sound as much as possible...
Price difference is not that major, BERK $98 shipped - MEGAN $95 shipped plus a CEL fix.
Your opinions are appreciated!
Old Feb 16, 2006 | 07:22 AM
Sideways's Avatar
The Berk is 6 lbs lighter.
Old Feb 16, 2006 | 07:42 AM
GPW03's Avatar
I don't think you could go wrong with either, but if the above statement is true I would go Berk!
Old Feb 16, 2006 | 07:43 AM
BrianGT's Avatar
I had the Megan test pipe on my s2000 before I sold it, and I used those spark plug extenders and it didn't throw a CEL once. It weighs a lot less than the cat, but am sure that the non-resonated one is lighter. I bought the resonated one, as it looks kind of like a high flow cat, so I might be able to pass the visual inspection that is done at most place here.
Brian
Old Feb 16, 2006 | 07:55 AM
overlord's Avatar
Does the resonated Megan pipe reall make a big difference in sound versus the non-resonated BERK pipe?
Old Feb 16, 2006 | 08:02 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Yes.
Old Feb 16, 2006 | 08:18 AM
S2kracka's Avatar
I've never seen a Berk, but the Megan piece has beautiful welds and comes with a gasket and bolts (not sure if the Berk does or not).
Old Feb 16, 2006 | 11:14 AM
CypherAZ's Avatar
yes, and yes
Old Feb 16, 2006 | 11:49 AM
acuraintegraman's Avatar
whichever one is cheaper *shrug* I got the berk and threw a code. One of the locals also threw a code on the Berk. I wonder if they had put the anti fouler in the opposite direction if that would eliminate all cel. Anyways, I think the eta on the Berk is late Feb so if you're in a bind, Megan should be in stock. As for the cel, do a spark plug anti fouler and you'll be good to go either way
Old Feb 16, 2006 | 02:50 PM
530s2k's Avatar
[QUOTE=acuraintegraman,Feb 16 2006, 12:49 PM] whichever one is cheaper *shrug*
