Mobil Oversize Filter Problems
Old Apr 16, 2003 | 09:16 PM
FormerH22a4's Avatar
Mobil 1 is a pretty restrictive oil filter. I wouldn't use it and the oversized isn't much of an improvement on the flow.
Old Apr 16, 2003 | 11:50 PM
Crabby Guy's Avatar
FormerH22a4, I have read that the Mobil 1, STP, and some Bosch model are essentially the same design, but with different materials. You are suggesting that a different, higher-flow design is more appropriate. What is the best examples for the S2K of such a filter? Also, why is filer flow important, since there must be a valve that opens when the filter flow is constricted?
Old Apr 17, 2003 | 12:44 AM
Daniel L's Avatar
It may just be my luck with my particular filter being out of spec or something but I think I'll stick with the normal sized one from now on. If my friend hadn't noticed the puddle of oil, I'd probably be in much worse shape right now.
Old Apr 17, 2003 | 05:43 AM
Chazmo's Avatar
Daniel, there's another possibility... Did you ensure that the rubber ring from the previous filter wasn't stuck onto the metal before you screwed on the new one?
Old Apr 17, 2003 | 07:30 AM
Gloffer's Avatar
I had an MI 105 oversized oil filter back out on me at the track. I thought just tightening it back up would fix the problem, but the O ring deformed and the filter kept leaking. This cost me one track session, while I borrowed a car and headed off to the local auto parts store for a new filter and a quart of oil.
No more Mobil filters for me. I've moved on to stock size K&Ns. According to the literature, K&N's have the same filtering capacity but with more flow. K&N's are a coupla bucks cheaper here, and they have that cool nut on the end for removal.
Here's a thread that may be of interest https://www.s2ki.com/forums/showthread.php?...?threadid=48839
Old Apr 17, 2003 | 11:01 AM
honda606's Avatar
I have the M-105 on the car right now. I've had it on for the past 500 miles or so and no problems at all. This thread does have me a bit worried though. I've always used this link for my S2000 oil filter information:
http://www.ntpog.org/reviews/filters/filters.shtml
Old Apr 17, 2003 | 03:01 PM
K&N oil filters are known for their flow rates and have decent filtering efficiency. The more restrictive the filter is the more of a pressure drop you will see. Also the Mobil 1 filters will clog up faster because they filter at the 10 micron range so if you run with dino oil then you should change the oil sooner if you are using a Mobil 1 filter.
If you want to see a comparision between flow rates of different filters, read this thread.
http://theoildrop.server101.com/ubb/ultima...ic;f=6;t=000513
Old Apr 17, 2003 | 03:07 PM
honda606's Avatar
Thanks a bunch for that thread. I'm almost inclined to go change out the filter only on the car and throw a different one on.
Stephonovich
Aug 2, 2018 01:26 PM
bkmagby
Nov 26, 2006 07:06 AM
GodoftheBOLP
Aug 16, 2004 12:34 PM
Ira
Jan 19, 2003 07:00 AM
