Modded S2000, what sort of power to expect?
Old Jul 14, 2009 | 09:49 AM
S2KNJ's Avatar
Originally Posted by xrapidx,Jul 14 2009, 11:03 AM
241.384hp at fly wheel - the tuner said their dyno is VERY conservative, and I can add around 5%.
Out of interest - I didn't do a dyno before the mods - what would it have been? I know specs say around 237kw - but thats probably under ideal conditions.
BTW - dyno done at the coast.
There was quite a big jump after VTEC for around 1000RPM
you can expect 241.790hp with those mods but it will feal like 242 even.
Old Jul 14, 2009 | 09:55 AM
sactoesquire's Avatar
various import tuning magazines have researched power gains on the S2K through the kind of bolt ons you've installed. You should see btw 4-8 hp gain. I don't think that translates much to actual power increase you feel but it should add to the driving enjoyment.
Old Jul 14, 2009 | 10:23 AM
stitos2k's Avatar
Look at it this way, if you decide to get a turbo most of those mods can be an asset. You'll loose the K&N obviously but the rest would probably be beneficial.
Old Jul 14, 2009 | 10:26 AM
xrapidx's Avatar
Wasnt expecting a huge gain - bit was slightly dissappointed. As long as its in normal power range and not under performing - I'm happy.
I'll upload the dyno chart as soon as I scan it.
Old Jul 15, 2009 | 05:12 AM
xrapidx's Avatar
Does this look right, graph at the flywheel
Old Jul 15, 2009 | 06:38 AM
Swiftoy's Avatar
Should have bought gears instead saved a couple of bucks and you would have a bigger grin on your face when driving. For the money gears are hard to beat they may not add HP but they sure do change how the car accelerates.
Swiftoy
Old Jul 15, 2009 | 06:40 AM
xrapidx's Avatar
The car had Rick's Final gear in - but the installer stuffed up and it was reverted to stock
Are the results fairly standard though?
Old Jul 15, 2009 | 09:14 AM
Swiftoy's Avatar
Obviously installation is everything. I have been on 4.44's for 14k miles.
Swiftoy
Old Jul 15, 2009 | 09:24 AM
lazymashi's Avatar
go FI if you want numbers...
Old Jul 15, 2009 | 10:18 AM
Siggy's Avatar
from all the dynos and such ive seen with boltons like yours peak wise you should be seeing ~10 whp and some decent midrange power.
Switch to a single if your really concerned about getting the most flow from your exhaust for sure.
