moldy, mildew, musty smell inside the cabin
Wasn't there a TSB for the AC draining into the cabin on the passenger side? If there is no wet carpet found anywhere, you can also try using a couple laundry dryer sheets in the cabin to help absorb any moisture and give it that clean fresh laundry smell.
Originally Posted by rustywave,Oct 1 2010, 03:53 PM
did you buy the car for cheap after katrina hit?
As others have already mentioned.Take out the trunk tool tray and liner and have a looksee.There was a writeup some time back as to the trunk vent at the rear upper portion of the trunk compartment that leaked.The water terminated under the tool tray area and was unnoticeable until you remove and inspect.
