Mugen hardtop
Old Jan 27, 2005 | 07:10 AM
medicalstudent's Avatar
Default Mugen hardtop
Not sure if this fits in "UTH", mods, move thread as it may seem appropriate.
I currently have the OEM hardtop. I am contemplating about getting the Mugen hardtop. Would it fit on my current setup or would I have to remove the OEM install kit and replace with Mugen install kit?
Old Jan 27, 2005 | 07:17 AM
xviper's Avatar
Until someone with a Mugen HT posts to confirm this, I believe it is the same hardware that holds on the OEM hardtop. I know of someone who sold an OEM hardtop and left all the hardware on his car because the Mugen was a drop on and go.
(Yeah, UTH material. )
Old May 12, 2006 | 11:07 AM
payyourtoll's Avatar
old thread but I have same question.
I have OEM top and want Mugen. Can I just swap the new top in with nothing else needed? Mugen instructions are horrible fyi
Old May 12, 2006 | 12:00 PM
Stratocaster's Avatar
I thought you already had a MG HT?
C4SxM5's Avatar
Yes you can swap the material but will most likely have to buy some new clips because they tend to snap and break when you remove them.
Old May 12, 2006 | 12:17 PM
What I prefer to do is leave all oem hardware in, and just drop the new top in. are the catchers or any other parts incompatible? What clips are you talking about?
Jeff - I do not have MG HT
Old May 12, 2006 | 12:43 PM
C4SxM5's Avatar
the clips that hold the weatherstripping together. the mugen tops comes with OEM hardware so it will work fine.
Old May 12, 2006 | 12:57 PM
sweeeet
Old May 12, 2006 | 01:49 PM
OK, but Tom (medicalstudent) does and he has both. He swaps them from time to time. So that makes them interchangable.
Old May 12, 2006 | 03:01 PM
Luder94's Avatar
Yes the mounting hardware is the same as OEM. The OEM hardtop mounts mounted in the car will accept a Mugen hardtop and vice versa.
The only thing that the Mugen hardtop doesn't compensate for is the defroster wiring. If you have a Mugen hardtop mounting kit and what to use an OEM hardtop, you WON'T have defroster capability unless you so add the wiring kit specific to your year car.
