My 06's VSA
Old Sep 15, 2006 | 02:42 AM
Rashido's Avatar
Default My 06's VSA
guys, i have an 06 s2k.. the vsa still kicked in after i turned it off when i tried launching it at 4,500 rpm. what do u guys suggest? shull i try launching at a higher rpm, let's say 6,000 or 6,500?
Old Sep 15, 2006 | 05:54 AM
ONEQUIKSTI's Avatar
Trade it in for an 05 ...just kiddn !!!
Old Sep 15, 2006 | 05:57 AM
Lionheart's Avatar
Try disconnecting the VSA switch/cable
Old Sep 15, 2006 | 08:32 AM
SheDrivesIt's Avatar
How do you know the VSA came on, is there a light for it?
Old Sep 15, 2006 | 08:57 AM
JackS's Avatar
If it did and this is common among '06's, there will soon be a TSB.
Let them fix a few first before having yours done.
Old Sep 15, 2006 | 09:01 AM
vishnus11's Avatar
you must not have disabled it properly. Hold down the VSA button till the "!" light on the dash illuminates constantly. Then rev to what rpms - 5k give or take, and dump the clutch.
Old Sep 15, 2006 | 09:15 AM
8kGoodENuff's Avatar
You probably didn't turn it off right. Do what he said and
Andre
Old Sep 15, 2006 | 09:55 AM
Nimbus's Avatar
VSA should not turn itself back on unless you either switch it on again or the car has been restarted. Most likely you never disabled it in the first place.
Old Sep 15, 2006 | 10:44 AM
Dave-ROR's Avatar
I'm only done this once and VSA did not kick on at all.
Are you SURE you disabled it?
Old Sep 15, 2006 | 11:05 AM
mikey k's Avatar
My 06 launches and donuts with the best of them with the VSA off!
