my 07 bog/lag
Old Jun 30, 2007 | 06:57 PM
radcliffe1's Avatar
Originally Posted by 6speedftw,Jun 30 2007, 05:19 PM
Don't AP2's also have a clutch delay valve?
I've guessed this was the reason.
And it's got so little torque it's sort a dog until thrid gear and then it goes.
Love the car however.
Old Jun 30, 2007 | 07:01 PM
CKit's Avatar
It's lack of torque FTW!
Get gears or FI. Or keep it in the powerband.
Old Jun 30, 2007 | 07:38 PM
GOS2K007's Avatar
Originally Posted by FISH22,Jun 30 2007, 04:18 PM
^the bog has nothing to do with that CEL for the O2 sensor. there was a thread a couple months back about this. i really cant explain it, but it has something to do with the ecu, and the way it controls the engine between the 1 to 2 shift and starting off the line. i know for me, i can avoid it, like mentioned above, by keeping the revs higher. if i shift from 1st to 2nd in the lower rpms, i will experience this bog after letting the clutch out...but if you keep the rpms above 3-4, you wont/shouldnt feel it. same with starting off from a stand still.
I have the same problem. Just keep the rpm's up and it won't happen.
Old Jun 30, 2007 | 07:51 PM
kingbriani's Avatar
ive noticed in stop and go traffic when im just coasting along at a few miles an hour going from no gas to gas the transition is really rough. like ill give it some gas and it hesitates a second and then lurches and itll do the same when you let off. dont know if this is related but its annoying.
Old Jun 30, 2007 | 09:42 PM
smurf2k's Avatar
OP example sounds like clutch delay valve
*note, i have mine removed. i can tell a big difference between shifts. HOWEVER, even with it off, if i drop clutch at 4000 or something, there is still a noticeable BOG... (just not as extreme as 1-2 seconds). can be ascribed to small displacement motor and rwd with sticky tires (eagle f1)
your example - any stumbling in low rpm - you may want the usual suspects checked: o2 sensor, distributor, plugs, plug wires, etc
Old Jul 1, 2007 | 12:45 AM
vishnus11's Avatar
For the millionth time...
1. IT IS NOT the delay valve.
2. IT IS NOT VSA
3. This bogging usually occurs between 2000-2750 rpm on 2006 and 2007 vehicles. It feels as if there's a "hole" in the fuel map, where the engine seems to just fall on it face. It's not the DBW system lagging on anything. I had thought that only 06s had this, and thats why Honda changed the ECU for 2007 S2000s but apparently this didn't fix it.
Old Jul 1, 2007 | 06:03 AM
donger274's Avatar
i thought it was because of its low displacements engine. higher rev= more power, lower rev no power
Old Jul 1, 2007 | 08:36 AM
smurf2k's Avatar
2. IT IS NOT VSA
CALM DOWN BROSEF
wheres the previous 999999th time that you have said this?
Old Jul 1, 2007 | 02:07 PM
JackS's Avatar
TRust your 6th sense to adjust for this. Without thinking your body will react to couner the bog and it will always be totally unconscious.
For me it's almost a thing of the past.
The bog I get now is so rare it suprises me when it does occur..
Old Jul 1, 2007 | 04:38 PM
Yflyer's Avatar
2. IT IS NOT VSA
100% -- my '06, stock, acts totally the same. The Honda tech admitted to me that it is a fuel map problem, and that Honda does not have a fix. I will keep complaining until something is available. My S is a D/D so this is a real PITA.
