My 1st s2000
In short, if peak dyno power is what you're looking for going the whole bolt-on route is going to be well; disapointing. For example... I was actually able to crank out an impressive amount of gains throughout the entire powerband *for N/A boltons*, but my reason for modding was just to amplify the feeling I had already, to make it sound and look the way I wanted my S to look. The gains while great compared to most NA gains on this car, are still dismal... so if that was the reason for my mods I'd be very disapointed. See what I'm getting at?
If you really want power, save up the 5-8k to get the FI kit you want, an engine management system, a tune, and installed. There's really no way of getting around it. If you want to make a difference in this car, you're going to need to save up some change.
whiteflash : I guess a 15-25/hp will be enough for the time being, as i said before i just want a little extra power!.
And my reason for modding is not a peak dyno power, i just want to enjoy the ride with a little extra power, a nice exhaust sound and a nice exterior. Thats it.
Thanks again!
Thanks again!
as CKit mention, try different gearing. it wont add hp but it will be noticeably quicker off the line..
what year is your car? does the buzzing noise happen when you decelerate from a low gear (2-3)? it might be gear backlash which is one of many normal noises the s2000 will make. the s2000 is noisy car overall, you might want to get use to that.
And i didnt really get what you guys mean by try different gearing.
Thank you
https://www.s2ki.com/stor/library/TSB/A00-054/index.htm
check this link out.. as I've mentioned, it's normal but can be fixed by replacing your clutch disk.
what we meant by gearing is changing your final drive gear in your differential to 4.77, 4.44, etc. i'm not to fond of this so it's time for you to do some research.. search the forum, there's also videos on youtube for comparison.
