my front wheels rub...
Old Mar 10, 2005 | 08:48 AM
kush only's Avatar
Default my front wheels rub...
my front wheels rub causing the tab that holds the fender liner and fender together to fall off. anyways, i heared some people who shoved the fender liner inside the bracket of the fender to get more clearance? how do you do that? thanks
Old Mar 10, 2005 | 09:47 AM
ttah's Avatar
It's a pretty ghetto solution. I just means you unbolt the plastic part around the lip and you shove up above the fender lip. If you're rubbing right around the bolt area then you might be better off having it rub plastic than your metal lip. You can also roll part of your front fender. Either way you're not gonna gain a lot of clearance in the front.
Old Mar 10, 2005 | 10:10 AM
SIIK2NR's Avatar
Originally Posted by AP1ayer,Mar 10 2005, 09:48 AM
my front wheels rub
Can you please tell us what set up your running? If you don't mind.
Old Mar 10, 2005 | 10:12 AM
kush only's Avatar
18X8 +55 OFFSET. its work meister s-1 3 piece.
Old Mar 10, 2005 | 10:14 AM
kush only's Avatar
there are about 5 bolts, do i remove all 5? or just the 3 on top?
Old Jan 30, 2006 | 09:53 AM
kayvan_pour's Avatar
Banned
ttt
garykoo
Oct 8, 2017 06:16 PM
Jeaners
Aug 8, 2013 04:57 PM
gotboost79
NYC Metro Stock Exchange
May 19, 2013 01:20 PM
tylorweaver
Mar 23, 2009 04:08 AM
