MY07 Soft Top Noises?
Old Jan 15, 2008 | 12:35 PM
boofer's Avatar
mine did that as well, so i sprayed some WD-40 on some of the screws and joints and the creaking all went away. also, sometimes if i don't close the top 100%, it tends to make some weird noises, so i hold the button for about a second longer after it appears to be closed before latching it shut.
Old Jan 15, 2008 | 01:05 PM
tcho82's Avatar
There is a post SOMWHERE about this. But if its a realllllly slight clicking noise, then its part of the soft top's frame hitting another part of your frame. It is where the joints flex. The metal hits the metal on another portion.
My quick fix was to get one of those tiny little felt circles, used to put under things to not let them scratch stuff. That stopped it for me.
Old Jan 15, 2008 | 02:27 PM
The Twanksta's Avatar
mine does every so often, it tends to go away after just few minutes. or I just open the latch and eclose it.
Old Jan 15, 2008 | 03:04 PM
nearwater4me's Avatar
Mine was quiet except some small ticking noise from the spring mechanism.
But recently I also noticed this creaking noise when it really cold outside.
I thought it was normal considering the temperature.
If I still have this creaking sound even in spring or summer, I'll have it greased.
Dan
Old Jan 15, 2008 | 04:32 PM
APhap2's Avatar
I don't know what yall guys are talking about....nothing is wrong with my 07 with 5031 miles. =) thank god!
Old Jan 15, 2008 | 05:07 PM
TCLAP2's Avatar
My 07 did the same 2 days after purchase, brought it back to the dealer and they claimed to put double side tape on the underside of the latches? but whatever they did it worked! never had the problem again.
Old Jan 15, 2008 | 05:10 PM
mikeyr's Avatar
mine does it sometimes, not often then again I usually don't have the top up.
Old Jan 15, 2008 | 05:31 PM
qsmarcei's Avatar
My roof latchs make a click under hard acceleration. Is that normal >.<
Old Jan 15, 2008 | 05:44 PM
Blacknot's Avatar
I drive with the top down as much as possible. Every time i put the top up and hear all the noise it makes me want to put the top back down.
Old Jan 15, 2008 | 09:38 PM
tak_one_77's Avatar
more stereo noise?
Its not that bad........
