Need Help, I have an urgent question on gas octane!!
Ok, i was extreemly tired this morning, and i accidently pu tin the "plus" gas, instead of "supreme". Am i going to have any problems? My car is totally stock, but i like to v-tec on the way home from work. Can i still do this? What are my options at this point? How bout a can of Octane booster? Please help me!
Its not going to cause you any major problems as the engine was built to primarily use 98RON, but can also use 95RON. I am assuming that Plus = 95RON and Supreme is 98+RON??
You can use an Octane Booster (I use Millers) to increase the octane level without any problems, but if you don't it will only take a couple of tanks of "Supreme" to get the octane levels back to normal.
Don't use an additive.
Personally, I think you'll be ok, just don't push it as hard as you normally do, drive it smooth and normal (for a car, not an S2000) and fill up when you can.
Other than that you could syphon your tank into another vehicle or can.
I bet you'll never do that again huh?
Thanks Guys. Thats what i thought, and no i wond do it again. The had the sticker removed on the spreme nozzle and i didnt realize that it was plus till after i pulled it out and thought the color of the nozzle looked unfamilar. Then i peiced it together. whoops!
Regular gas won't do any damage, but you'll probably notice a drop in fuel economy because the knock sensors will adjust the spark advance to prevent knocking. This happens because we have a high compression engine, and higher octane fuel burns slower, preventing the car from knocking.
When I take long trips in my car, I use regular gas because I'm basically not doing much of anything besides cruising at a relatively constant speed. In that case, the added cost of high octane fuel is just a waste of money. Also, the Owners Manual says it's OK to use if necessary.
