Need HELP! Question about 4 or 5 point harness
Old Aug 18, 2002 | 10:26 PM
alexf20c's Avatar
the s2000's roll hoops, which are attached directly to the main frame, is plenty safe for a rollover; it will not collapse. the issue is if the driver's head, with or without a helmet, breaches the safe zone... or extends past the roll hoops.
there are several options available:
you could install aftermarket roll hoops (not a full cage), but you would likely make the s2000 a hideous monster (i.e. the 550 Barchetta and 360 Spider).
a full roll cage is available but would be ever-hideous if you ever put the top down. a hardtop would fix this problem, but then, it would almost defeat the purpose of a roll cage, as the SCCA and most club racing organizations require either a roll cage or a hardtop, not both.
you could also wear turtlenecks...
and i agree with the others when they say racing harnesses should NOT be installed if there is no roll cage or taller roll hoops installed.
hmmm... i just remember the question of this thread, and it has nothing to do with roll cages. back to the topic, if the strap is digging into your neck, a shoulder pad will not help, as it is a shoulder pad, not neck pad (hence the name). try adjusting your seats; are you sitting too close? too far?
as for manufacturers...
http://www.kingmotorsports.com - distributor of Mugen parts (full cage, 5-point harnesses)
http://www.spoonsports.co.jp - exclusive Honda tuner, though quite pricey; they make a full cage as well. i don't know of any U.S. distributors off-hand, but check the website to see if there's anything you like. HINT: surf the Japanese website, as the English site doesn't have a "Products" section.
Old Aug 19, 2002 | 04:34 AM
Triple-H's Avatar
Originally posted by alexf20c
you could install aftermarket roll hoops (not a full cage), but you would likely make the s2000 a hideous monster (i.e. the 550 Barchetta and 360 Spider)...
Beauty is in the eye of the beholder!
I'm adding a rollbar to my car because of track events. Cars I have seen with them, I think look very cool. Must be I'm biased because most of the Z3s I see have roll bars because most of the people I hang with are driving school enthusiasts.
I completely agree with the general direction here, DO NOT install a harness unless you have a rollbar added or a cage, just like others have said.
The debate over belts or a harness in the event of a roll over with a car equipped with a rollbar or cage gets MUCH more complex when you factor in that many tracks have gravel/sand traps on the outside of the corners. If a car rolls over in that, the rollbar and the roll cage will do no good because the thin bars will just sink into the sand. Now you can talk about body compression, an ugly thought for sure!!!
Old Aug 19, 2002 | 05:16 AM
alexf20c's Avatar
duh, i said to wear a turtleneck
Old Aug 19, 2002 | 08:47 AM
Ken Coffey's Avatar
Good food for thought! Clear risk for rollover but clear benefit in other types of crashes.
Old Aug 19, 2002 | 08:52 AM
alexf20c's Avatar
turtleneck
Old Sep 2, 2002 | 08:50 PM
twohoos's Avatar
...a hardtop would fix this problem, but then, it would almost defeat the purpose of a roll cage, as the SCCA and most club racing organizations require either a roll cage or a hardtop, not both...
Actually not true -- none of the available hardtops are intended for, or capable of, providing rollover protection. They're lightweight and will crush easily; even if they didn't, they're held on with itsy-bitsy clips and clamps and they'd separate easily from the car.
Hardtops are for looks and aerodynamics, not safety.
Old Sep 2, 2002 | 09:09 PM
Wael El-Dasher's Avatar
I thought reading specifically in the SCCA rule book that hardtops are not considered roll over protection. I will check the Solo I section again to be sure.
cheers
W.
Old Sep 2, 2002 | 09:31 PM
Strike's Avatar
God, I sure hope they don't consider hard tops rollover protection. The hardtops I've seen at the track that rolled did not look good, to say the least.
Skatethesea
Feb 15, 2010 08:52 AM
Globe182jp
Mar 13, 2009 08:56 PM
roadents2k
Jan 28, 2006 09:28 AM
Hyper-X
Apr 26, 2004 03:49 AM
CoralDoc
Feb 20, 2003 05:30 AM
