Need Honda Alarm Help ASAP
Old Apr 22, 2004 | 06:23 PM
NFRs2000NYC's Avatar
Default Need Honda Alarm Help ASAP
Whats up guys......Im helping a fellow s2000 owner install a stereo, and have a problem.
I dont have a factory alarm so I have no idea....
I had to remove the battery to stick the power wire through, and then when I reconnected it, the horn continuosly sounds, I cant stop it, and the top wont go back up. Whats goin on???
Thanks for the help!
Old Apr 22, 2004 | 06:48 PM
Barry in Wyoming's Avatar
I have a Honda OEM alarm and when I installed my stereo I had to do the same as you and I had no problem.
I think you can download a pdf copy of the Honda alarm instructions.
See if this Odyssey alarm manual has any info.
http://www.handa-accessories.com/odyssey/o.../odyexalarm.pdf
Barry
Old Apr 22, 2004 | 07:02 PM
Well....since the batt is connected, and the top wont go down....what happened?
Old Apr 22, 2004 | 09:46 PM
xviper's Avatar
Maybe you blew a fuse.
Old Apr 23, 2004 | 07:21 AM
If the top wont move, and the horn continuosly sounds.....any idea as to what fuse to check???
Old Apr 23, 2004 | 09:54 AM
xviper's Avatar
The horn sounding is because power was interupted to the alarm. Try pushing the disarm button on the key fob when the horn is going off. This "should" turn off the alarm.
As for the top fuse,
You must check fuse #5, 7.5A, in the driver's footwell fuse panel
AND
fuse #25, 7.5A, also in the footwell panel.
Both of these fuse the convertible top control unit.
Also, if those are OK, look at fuse #52, 20A, right top motor
AND
fuse #55, 20A, left top motor.
These are located in the engine bay in a black box near the battery.
westlondonsun
Jul 3, 2013 03:13 AM
x2k
Aug 23, 2008 09:15 PM
Syncro9z-S2K
Aug 19, 2006 05:29 PM
Boab
Apr 16, 2006 02:44 AM
jonnybravo
Dec 6, 2005 11:53 AM
