Need a New Clutch!
Old Aug 27, 2008 | 05:48 PM
daniel3ooo's Avatar
Originally Posted by tlee1234,Aug 27 2008, 05:36 PM
cdv (clutch delay valve)
sorry...I have no clue what that means .....could you elaborate more?
Old Aug 27, 2008 | 06:22 PM
tlee1234's Avatar
you should use the search button ,
cdv is basically a delay valve that makes the clutch slip to protect the rear dif. ( so it doesn't blow) only when you shift fast ap2 and later ap1's have it
Old Aug 27, 2008 | 07:39 PM
Suzukuh's Avatar
Ap1's do not have a delay valve. Ap2's do have one as well as a heavier flywheel. If you are replacing your clutch for your situation it sounds like OEM will be just fine. Here are the things you would need:
Flywheel
Friction Disc
Pressure Plate
Throwout Bearing
If you have an AP2 you can go with the heavier flywheel for an extra 10$. Also I would have the delay valve removed as it annoys me driving my gf's car. You can do some reading on here using the search function to get some more info.
Ryan
Old Aug 27, 2008 | 08:11 PM
daniel3ooo's Avatar
[QUOTE=daniel3ooo,Aug 27 2008, 05:33 PM]Guys,
Just wanted to confirm something...
Again this is my first manual car in many years.
Old Aug 27, 2008 | 08:23 PM
Suzukuh's Avatar
I believe the last part you said is a sign of the clutch slipping. If you are letting off the clutch and it doesn't engage until its near the top then yes you should probably replace the clutch. I am not super familiar in all of this but it sounds like a clutch replacement is in order.
Old Aug 27, 2008 | 08:34 PM
tlee1234's Avatar
i believe some ap1's have cdv (03)'s i believe
Old Aug 27, 2008 | 09:25 PM
Suzukuh's Avatar
Being that the 02 and 03 are basically the same car they don't have CDV's. They only exist on the AP2's as they were added in 04.
Old Aug 28, 2008 | 10:35 AM
00CivicSi's Avatar
It's been long since confirmed on these boards that some of the late '03s (AP1s) received slave cylinders with the CDV during production. Therefore, some AP1s do in fact have CDVs.
Correct!
Old Aug 28, 2008 | 12:38 PM
qbmurderer13's Avatar
Why was the cdv even brought up when its clearly a slipping clutch?
Old Aug 28, 2008 | 01:02 PM
mmm def's Avatar
Yeah here we go again with the CDV stuff.
