Need to replace shocks and struts
I just turned 100,000 miles on my 2000 S2000. I need new shocks but Honda doesn’t make the stock shocks anymore. I started researching but there is a ton of information out there that is confusing. Any suggestions? I don’t race, am not interested in lowering the car and don’t intend to get involved in adjustable shocks. Just want the best ride.
You can still purchase new shocks from Honda, they just don't sell the entire shock absorber assembly with the spring and upper mount.
Fronts are around 210 a piece:
51605-S2A-A05
51606-S2A-A05
Rears are around 250:
52611-S2A-A04
52612-S2A-A04
51605-S2A-A05
51606-S2A-A05
52611-S2A-A04
52612-S2A-A04
If that is too expensive, you could look for lower mileage used shocks (that someone removed to install performance suspension). But you'll need to look for a long time, as these are getting hard to come by.
Another option is Koni shocks. Most people go for the Koni Yellow's, since they are adjustable, and everyone wants a shiny knob to play with (phrasing!)
But there is also a Koni Orange, the non adjustable version. Similar to Yellow but not adjustable. Stock ride height. Decent performance. Probably a little bit more comfortable than stock (softer compression damping). Maybe a little bit more dive on braking. Way cheaper than new oem.
I have seen so many posts from high milage folks that never mention a shock maintenance issue. Clutches and top replacements seem to be the top ones.
[QUOTE=Fokker;24354695]Finally hit 200K miles. My 2005 SSM has been on road trips, track days, and autocrosses, as well as seeing daily driving duties.
Only repairs of significance have been a clutch replacement, axle cup swap, top replacement, and a wheel bearing. Anything else I've done has been performance upgrades.[Quote]
I'm creeping up on 210k miles. I have done quite an extensive bit of maintenance since I've gotten her.
-all fluids
-replaced iacv (idle drop issue)
-replaced drive belt
-replaced idler belt
-replaced tensioner belt
-replaced all shifter components
-replaced oil seal gasket
-replaced vtech upper and lower solenoid gaskets
-replaced filters
-upgraded deck and speakers
-got new oem red floor mats
-reconditioned headlights (plan on doing lense swap)
Getting some rear tires tomorrow. My clutch is going out. So I need to get that replaced. Also my rotors are getting a bit worn. It never stops, but I'm getting closer to a mechanically sound s2000
-all fluids
-replaced filters
I can agree with this.
At 100K miles, shocks are close to ready for replacement.
Honda build quality spoils us because their chassis parts will continue to work even after they're well past their prime. Shocks, ball joints, bushings, etc all wear. But since they don't leak, make noise, or break apart for a long time, people don't consider them as part of major maintainence.
I can say from experience, though....a chassis refresh at 100+K miles does make a miraculous difference.
However, at 100K miles, a leaking or totally worn monotube performance shock is not surprising at all either.
Hence, why I suspect after everything I've replaced at 138,000 miles, the culprit are the dampers themselves.
I have a set of KW V3 ready to go, my only regret is that I haven't the car on a track with the OEM dampers yet. (As Honda intended)
Moddiction
Jul 7, 2008 08:38 PM
