Need Some Tranny Help.
Old Jun 2, 2011 | 10:12 PM
702.s2k's Avatar
Default Need Some Tranny Help.
Hey guys. I'm new to the s2k seen. I just picked mine up about a month ago and 2 days after i had it i spun it around and put it into a nice light pole. I got all the body work fixed. It broke the knuckle on the driver side so i replaced that. Got the alignment at work and my brake and front end tech (I work at Ford -- service advisor) told me i need a lower control arm on the driver front. Looked at it and it was a little tweaked. But my real question is that i've been daily driving it back and forth to work and the shifter is offset. Its closer to the driver seat that it normally was. I noticed it, and thought when i crashed that i had no 5th or 6th being that the shifter did not go as far over as normal. But when i drove it, it shifts just fine, it goes into reverse just fine. It just seems to be moved over towards the driver a little more and 4th to 5th is real short. Any ideas? Sorry if this is posted in the wrong section. If i need to post it somewhere else let me know. Thank you.
Kyle.
Old Jun 3, 2011 | 05:55 AM
davgoat's Avatar
Check your engine and Tran mounts they are one of the weak points on this car specially if you run into something. Tran. may have shifted over
Good Luck
Old Jun 3, 2011 | 05:04 PM
702.s2k's Avatar
I thought of that last night as i was driving home. I stopped at a light and the car had a real bad rattle in it. Got home to find the outlet on my hks on the drivers side is rubbing my rear bumper. So i think that everything from the motor back has shifted over. Gonna put it on the rack at work tomorrow and get a closer look.
S2LEGEND
May 8, 2009 11:13 AM
ImportSport
Jul 24, 2006 07:23 PM
04RioS2k
Jun 28, 2005 06:52 AM
mwy23
Apr 3, 2004 06:27 AM
