New to me S2000...bone stock low milage...what to do?
A member here has been selling them for several months. You'll probably have to poke around the threads until you find him. Factory OEM in the Honda box from what I've read. I think they ship UPS.
-- Chuck
-- Chuck
I just purchased my first S2000 as well in October. Bone stock 2005 GPW from first owner who dealer maintained its entire life. Had been sitting on a non op registration for the last 3 years since the prior owner wasn't able to physically drive manual anymore.
After purchasing, I've done the following to make sure it's running well, while keeping it fully stock:
- Replaced all fluids (oil, oil filter, coolant, manual transmission fluid, differential fluid, clutch fluid, brake fluid)
- Installed new brake rotors and pads
- Replaced engine air filter
- Replaced serpentine belt
- Replaced starter with Denso reman off of RockAuto (starter was sticking 1 out of every 2 starts)
- Replaced OEM timing chain tensioner (TCT) with Billman TCT (contacted Billman through this forum)
- New set of 4 summer tires
- Changed 2 front map lights, trunk light, and rear license plate light to LED
- Installed new convertible top elastic straps (old ones were crunch & sagging)
- Removed corrosion from map light contacts (map lights wouldn't turn on consistently when doors were opened)
- Replaced Missing Fasteners to Under body panels
- Currently in the process of overhauling the shifter with all new parts (spring, boot, pivot cover, Honda urea grease, etc.)
- Valve adjustment is next
This thread is devolving into the same content already well covered by the sticky thread, that covers things new owners should do and check.
Plz go there and find all the answers you need.
Meanwhile, on rear fender openings, we should make clear there are now two distinct products being discussed.
Originally we were discussing the rubber strips with metal core that seal onto rear fender lip (and that can promote rust if seal ever broken and strips reused).
More lately we're talking about Side Strakes. These are dealer installed optional aero mini spoiler type things that are applied to lower rear fender in front of wheel. These now sell used for upwards of $600, new in box around $1k.
There are ebay reps, sometimes available, painted, around $150.
I recently purchased a 2007 all original with <18,000 miles. I am 81 years old. I have owned an 04 and a 2008 CR. Got all my thrills out of the CR. This '07 will just be a Sunday cruiser and occasionaly a local show and Coffee and Cars participant.
To Car Analogy, actually on the matter of the rear wheel openings there are 3 products being discussed - the fender well lip trim, the side strakes and the rear fender liners for AP2's.
So many times in the past trying to learn about these cars, I'd be piecing together details from multiple threads. Shards of info, often unclear or ambiguous. The people in the thread understood but otherd following along easily might not.
We often tell people to search first before asking, but then threads with answer often require a certain level of knowledge to even understand.
I'm always picturing someone like I was then. New to this platform, trying to learn. Trying to understand the answer to a question, but its all murky and vague.
Maybe they even think they understood, but actually bc there is so much they don't know yet, they totally misunderstood.
Always thinking about that person, not just the people interacting in the thread.
Hi guys! Thanks for the replies! Really appreciate it. Looking back at my post, it was very NOOB and likely I should have done more research first. My apologies! But I did get lots of helpful info! Thanks :-)
Ah yes! Thanks for clarifying the technical terms.
So this would be the "Lip Trim". When you say there is a sealant applied on install, you're talking at the factory when they install these, they apply a sealant in the cavity of the trim, and then apply it to the wheel arch?
-What kind of sealant are we talking about when reinstalling it?
-If I remove these altogether, I'm not entirely clear on what the most solution for rock protection would be?
Seeing as there never was an OEM offering for either the AP1 or AP2 rear fender liners, then provided I don't regularily drive in rain or salt/dust controlled roads...I likely won't have any issues.
The few S2000's with rust I've seen are likely daily driven cars, that even in California, can develop rust like any Honda. Though I'd imagine the garage queens driven on sunday's and never in the rain will likely not see the rust issue ever. Does that sound about right???
How many hours of labour does a valve adjust usually run at the honda dealer? Is this something their speciality tech needs to do...or is it just like adjust the valves on a Honda CR-V as far as the tech experience level is concerned?
Only modification is actually that it has an aftermarket head unit, looks like so the previous owner could use his sat radio. I don't love the 90's look alpine head unit, but all factory radio controls (the ones left of the steering wheel) appear to work and the aftermarket head unit is supposed to offer better quality with the OEM honda speakers. A least I can keep the stereo cover closed and I don't have to look at it lol.
Will do!
This is what I was thinking. And to be honest, I'm surprised the factory unit is bolted in place as opposed to just 3m tape. I would feel like a criminal drilling a hole in any part of the s2k lol.
2. Don't tell anyone but I've had an "eBay" (love how guys write eBay like it's a brand name!
) rear ducktail spoiler on my 2006 car for over 10 years. Held on by 3M double-sided tape -- no drilling necessary. Color match is perfect -- certainly as good as the OEM front lower spoiler that came out of the box brand new. Doesn't weigh enough to require fitting heavier springs to hold the trunk lid open..
-- Chuck
If you remove the lip trim altogether, the best alternative for rock protection would be new replacement lip trims with a bead of silicone squeezed into the opening of the trim before installing. Some of that will come out on the outside of the trim on the surface of the quarter panel - just wipe off with mineral spirits immediately. Some will ooze out on the inside of the lip. If you do a complete cleaning of the inside top of the lip and partially up the inside of the side wall (an inch or so) of the wheel well above the lip along the whole length of the lip, then you can augment whatever oozes out with additional silicone to completely fill the gap between the trim and the side wall and round off that with a finger to seal that space completely so that any water in the wheel well will flow out over top of the top side of the trim rather than down into the gap. Unfortunately this doesn't keep moisture away from the bolt that holds the front corner of the bumper to the quarter panel. That is where rust starts on UK vehicles from the galvanic action between the bolt and the quarter panel. But the trim is the best rock protection for the lip.
My car is minty minty with zero rust (lucky me). It must have had a well kept life, void of any winter driving or excessive moisture.
That said, you mention the galvanic action between the bolt and the quarter panel. Is this bolt you mention visible? I'm assuming it's an M6x 20 or similar. What about replacing the bolt with a stainless steel one, or even the a nylon bolt with the same thread/size. Would that eliminate the galvanic action?
danhuut
Aug 6, 2021 06:04 AM
