Rear Jacking Bracket?
Hi All,
Looking into different ways to get under my car, I've come across this link over at s2ki...
https://www.s2ki.com/faqs/faq_jack.php
Anybody know where this "rear jacking bracket" is? I've purchased the 2000/2001 S2000 Service Manual, but the picture in *this* manual (pg. 1-11) seems to imply that the differential should be used as the center jacking point. Which is correct? I've peeked under the car as best as I could, but I don't see any special bracket in the rear.
Thanks in advance!
Thanks in advance!
Ever try to get a mobile hydraulic jack under the front jack point? Putting it there isn't the problem- raising the jack is another thing... I had to strategically position the jack facing the wheel well and then use a large screw driver to raise the jack - the provided handle was way too long to be used in these tight quarters.
-B
-B
Since then I bought a pair of plastic ramps that get the front end up even higher. I use these ramps every 2-3 weeks when I change my tires for autocross. Here's a picture of the new ramp:
Originally posted by KenS2K
Tom, Where did you find the plastic ramps?
http://www.s2000online.com/forums/showthre...p?threadid=1768
bguernsey, here's a link to my PhotoPoint album with info on the wheels and tires:
http://albums.photopoint.com/j/AlbumIndex?...14098&a=7188323
