New Megan Header for the S2000!
Old Feb 3, 2006 | 12:01 PM
  #211
cap1's Avatar
Originally Posted by mugenpower_s2k,Feb 3 2006, 12:42 PM
waitting for the dyno results...
subscribing...
Old Feb 3, 2006 | 01:10 PM
  #212
RoaringVtec's Avatar
I'm going for the baseline dyno this weekend, and latest tuesday i'll have the header on with results. I had the headers on and now i have the stock one on, i'm not keeping them whatever the results are but i could tell you the powerband is a lot smoother and the car seems to rev more freely. The intake sounds louder from 6.5k and up, so i have a really good feeling about this header. Any one who has header may relate to the sound i'm disliking, it sounds like a leak, like sand inside the exhaust pipe. I've been told, and i've read that due to the thinner walls on the header the exhaust flow is heard and valves... i dont' know but if you get it you'll see what i mean. I know it's not a leak because it was checked at my local exhaust shop.
Weight = 9-11lbs very very light maybe that's why exhaust flow is heard so much. The weight is correct but give or take just incase my scale is a bit off
Old Feb 3, 2006 | 03:38 PM
  #213
stena's Avatar
Hi.
You promised a Video of the car under the hood....So we see and hear the header.The video quality should be the smallest 160x120?
If you can deliver please do.And if I get you right why are you against of keeping an Aftermarket header?
stefce
Old Feb 3, 2006 | 03:43 PM
  #214
I seriously dislike the sound, it sounds like a bad exhaustleak under accel. I have taken several video's but the sound isn't detecable. The sound of the intake hum overpowers it, but when you're actually accelerating the car specially at low RPM's it sounds really bad, junky car. I'll see if i could get a betterrecording device, better quality so you could hear what im talking about, i'll upload the dyno video anyways
I'm not against aftermarket headers but if the gains are not substantial then i rather keep a nice sounding car. If you search "header leak" you'll see several people complaning about this typical sound/noise, supposively heard because the walls of the runners are thinner and the exhaust pulses are heard like a ticking/leak sound.
Old Feb 3, 2006 | 04:28 PM
  #215
VIC4UF's Avatar
^^and you said you heard the same sound with Rick's header?
Old Feb 3, 2006 | 04:35 PM
  #216
yes sir, others have heard in Toda and others claim Comptach is the loudest, seems that high compression and thin walled header runners don't go together, i'ts normal thing but for my taste, don't like the sound
Old Feb 3, 2006 | 09:24 PM
  #217
Silver9k's Avatar
Sounds like it is a good thing I plan to wrap my header then whenever I get one. In doing that, I probably wont hear much of a change at all.
Old Feb 3, 2006 | 09:27 PM
  #218
WyattH's Avatar
I bet the J's is quite loud than. Thin walls.
Old Feb 3, 2006 | 09:56 PM
  #219
NFRs2000NYC's Avatar
If its sounds "tinny (tin)" then its due to thin walls.
Old Feb 3, 2006 | 10:20 PM
  #220
24s2k7's Avatar
Dont dynapacks usually pull much higher #'s than other dyno's? How did they only get 196whp from a stock ap2? I have seen ap2 dynapack dynos where stock they got like 230whp
