New Megan Header for the S2000!
Old Nov 21, 2006 | 05:26 AM
  #331
Emil St-Hilaire's Avatar
Active Streak: 30 Days
3 H.P.???that's all you gained.???
Old Nov 21, 2006 | 05:56 AM
  #332
Sideways's Avatar
Originally Posted by luisS2K,Nov 21 2006, 05:45 AM
i have an ap2 with aem v2, megan header, catless and stock exhaust.
the first picture is the car catless and with different rear tire diameter. temperature was about 93.5 F and 42% humidity
max hp (stock tires) 201whp max hp (larger size 255/40/17) 199whp
this one is like it is know. header intake no cat and stock exhaust. 91.77 F and 50% humidity. max whp 204 max tq 146
in puerto rico the humidity and heat makes cars lose a few whp. right know i'm thinking in getting a T1R exhaust to see how it performs.
I'd like to see a dyno with forced induction. This header is larger and should be more significant in that arena. I know one individual that will be testing with over 1 bar of boost and the results should be available shortly.
Old Nov 21, 2006 | 12:59 PM
  #333
luisS2K's Avatar
remember i'm still on stock exhaust. any gain from the header can be damped by the exhaust
Old Nov 21, 2006 | 03:22 PM
  #334
HMCK20's Avatar
you have basically the same setup as me. AEM V1, Test Pipe.
Old Nov 21, 2006 | 03:32 PM
  #335
Al3x_666's Avatar
3whp whitout exhaust, thanks for the infos!!
Old Nov 21, 2006 | 03:43 PM
  #336
Sideways's Avatar
I am amazed you got any improvement at all with the factory exhaust. Good point.
The acid test is to put a low resistance exhaust on and see what you can get.
Old Nov 21, 2006 | 03:47 PM
  #337
stena's Avatar
Well Megan's Site says 14 WHP with Header,test pipe and the Drift Spec Exhuast...
Old Nov 22, 2006 | 01:35 PM
  #338
abv's Avatar
abv
for all its worth...I have an ap1 reving to 9200rpm and at 11psi
making 365rwh on sean churches dyno with the megan header and test pipe ...I did abunch of stuff at once so i cant say that the pipe is doing god or bad but he did say that there arent oo many s2000 out there past 350 with a stock head.....personally i dont regret buying the header.. for people who are looking at top horespower get an exhaust made and call it a day for anyone else the thing costs next to nuthin and its way lighter than the stock...o by the wat the collector is lower than stock about as low as the toda....for all you suspension lowering types
Old Nov 22, 2006 | 03:39 PM
  #339
HMCK20's Avatar
yikes might be scrappin on my car o well
Old Nov 22, 2006 | 04:54 PM
  #340
luisS2K's Avatar
i'm at stock height but you cant see the collector nor the connection to the test pipe. i'm thinking to lower it with eibach springs so i will find out if it scratches.
