New radiator
Old Oct 14, 2016 | 02:17 AM
S2KJDM87's Avatar
Default New radiator
Hey guys i need help here. So star my car and drive it to store not long ago then when i start the engine i heard crank crank then drove home. I noticed that my radiator is leaking and when i check it. It run out of coolant. So i guess when i drove the for sure it has no coolant. Now i was in my garage i started the engine and the temp was in the middle. I turn it off and planning to replace a new radiator. My question do you think i damage the engine? And do you think it will start OVERHEATING even if i replace it with new radiator?
Old Oct 14, 2016 | 09:04 AM
Car Analogy's Avatar
Matbe it caused damage. First fix your radiator. Make sure its not just a leaking radiator cap.
No matter what, you now have air in the system, so you'll need to bleed that out once its fixed. That can challenging to get it all. You may think its good, only to overheat and really destroy your motor if its not already damaged. Heat should blow so hot it feels like it will burn your fingers. If not, there is still air. It may seem to run at correct temp, but it will suddenly overheat without warning. So make doubly sure all the air is out and heater blows very hot.
Old Oct 14, 2016 | 10:50 AM
S2KJDM87's Avatar
Thank you
Old Oct 14, 2016 | 12:23 PM
sam_spider's Avatar
Site Moderator
Community Influencer
You don't need 9 threads on the same topic scattered throughout the forum.
Old Oct 14, 2016 | 05:29 PM
bgoetz's Avatar
Replace and bleed proper and you will be fine.
Old Oct 15, 2016 | 04:20 AM
rpg51's Avatar
Did the engine get HOT?
Escort User
Apr 14, 2008 08:29 PM
Lickermat
Sep 15, 2005 07:29 AM
medicalstudent
Mar 1, 2005 07:51 PM
