New Rear Bridgestone Tires
Old Dec 12, 2000 | 12:12 PM
S2KRAY's Avatar
Active Streak: 30 Days
Top Answer: 1
I had 2 new Bridgestone Potenza Pole Position tires (225-16) installed about a month ago and after reading all the info on this board I'm a little confused. They dont have that OEM number that someone posted which is on both size tires(front and rear)and I got them from New Tire in Delaware who ordered them and said they are compatible with the OEM front tires. I dont think they are, however, I cant see any difference in handling between the original tires and these. I dont drive over aggressively but I do push this car and all seems fine. The fronts will need to be replaced in the Spring so I guess I would have to order the same tires from New Tire for the front. Make sense?
Old Dec 12, 2000 | 12:25 PM
STL's Avatar
STL
So your rear tires don't have 92W anywhere on the sidewall? Here are several the different types of S-02s made (not counting the Pole Positions): http://www.tirerack.com/tires/Spec.jsp?mak...el=Potenza+S-02
Notice the Honda OEMs are the two on the chart that do NOT have specs, and they are the only two W-rated S-02 tires.
[This message has been edited by STL (edited December 12, 2000).]
Old Dec 12, 2000 | 12:32 PM
Squeezer's Avatar
What is a W rated tire? Is it better then a Z rated tire?
Old Dec 12, 2000 | 12:36 PM
VA S2K's Avatar
According to Tire Rack, W-rated tires are good up to 168 mph and Z-rated are good for 149+ mph
Old Dec 13, 2000 | 04:33 AM
S2KRAY's Avatar
Top Answer: 1
No they dont STL, guess I didnt get the OEM's. Mine are ZR rated and thats fine as I'll never see 149mph let alone 160+ so I'll go with these tires on the front in spring and just live with it. [QUOTE]Originally posted by STL:
[B]So your rear tires don't have 92W anywhere on the sidewall?
Old Dec 13, 2000 | 05:40 AM
STL's Avatar
STL
Actually you got OEMs -- just not Honda OEMs! Looks like you probably have the N3 Porsche OEM tires. Do you happen to have a digital camera? If you do (or can get one), would you mind taking a close up photo of the tread of one the rear tires?
Old Dec 13, 2000 | 05:48 AM
STL's Avatar
STL
Here are the kind of pictures I am looking for (or maybe just confirm your rear tire's tread looks like the last picture):
See below...someone quoted this message so the pictures were in this thread twice -- which only makes it take longer to load! So I removed them from here...
[This message has been edited by STL (edited December 16, 2000).]
Old Dec 13, 2000 | 05:49 AM
Luis's Avatar
[QUOTE]Originally posted by Squeezer:
[B]What is a W rated tire?
Old Dec 13, 2000 | 06:05 AM
STL's Avatar
STL
[QUOTE]Originally posted by Luis:
[B] If you ever go beyond 168mph then you definitely need a Z rated tyre, otherwise a W rated tyre will do.
Old Dec 13, 2000 | 06:19 AM
S2KRAY's Avatar
Top Answer: 1
Thanks STL, no I dont have a digital camera but I will compare thses pics to my rear tires. I think mine are different in that they have a groove running down the center but I'll chack and let you know. [QUOTE]Originally posted by STL:
[B]Here are the kind of pictures I am looking for (or maybe just confirm your rear tire's tread looks like the last picture):
Honda OEM S02
