New T1R Product info
Hi Guys,
We have been working hard to develop these new suspension pieces for the S2000. We now finally got them done and they are now available.
Introducing the new T1R B52 damper kit
Specs:
-46mm piston valve for wide range adjustment **damper range covers for daily driving and weekend racer**
-36 way (single) compression and rebound adjustable
-Forged chomoly steel thread body
-Forged aluminum components
-Comes with pillowball uppermounts with high tension bearing
-high quality silicion dust boot
-cold forming wounded springs with F&R 12k spring
Also, the new T1R Anti-bumpsteer kit
Front
"Do you ever notice how your wheel tugs when driving over un-even roads at high speeds on a lowered S2000? The angle on the steering tie rod has changed due to the lower ride height from coilovers or lowering springs..etc. The factory has designed the steering system to be optimized at the stock height. It takes very little angle in the wheel to make the car steer. The T1R bumpsteer kit returns the steering tie rod to the more optimal and to create stock-like suspension angle."
Specs:
-made out of Forged aluminum (comes with high tension steel bolts)
-20mm thick
Applications : AP1 AP2 00-07 S2000
Rear
"The T1R anti-bumpsteer kits replaces the the rear toe rod of the S2000. By replacing it, it solves two of the most common problem of the S2000 rear suspension: It reduces and nearly eliminates potentially dangerous bumpsteer in cars lowered up to 2.5-3 inches. It also allows independent adjustment of rear toe, camber and the rod leveling. The T1R anti-bumpsteer kit is made out of A6061 forged aluminum with high tension spherical bearing for quality assurance. Available for 00-07 S2000. "
If you guys have any questions, please post here
Thanks
Ben
Specs:
Front
Specs:
-20mm thick
Rear
Thanks
Ben
im really looking forward to get some feedback on the front anti-bumpsteer kit.
had the BMAX 52's in my possession for a little over 2 weeks, they just sat in my garage waiting for a friend to come pick them up.
Come on !!! You guys don't go on our website at all
Prices are on A&J Racing
If anyone interested to buy a couple or few things together, I can work out a combo deal
