Noob question
Old Feb 13, 2006 | 04:25 PM
hamsterguy67's Avatar
Default Noob question
Searched for the answer and I couldn't find it, so here I am:
Noob question for you all, planning to change my own oil.
Will changing my own oil void my warranty? Guess I've never cared about a warranty until this car, but now it's an issue
Reason I'm asking is how does one prove the oil was changed at correct intervals? The maintenence manual has a place for a "seal" to be placed by mechanics. Can I just sign that box? hahahahah
Old Feb 13, 2006 | 04:27 PM
NFRs2000NYC's Avatar
Nope. Just use the right stuff, and youll be fine.
Old Feb 13, 2006 | 05:05 PM
JLEEzAP2's Avatar
what exactly is the "right" stuff?
Old Feb 13, 2006 | 05:13 PM
S2kracka's Avatar
10W-30 oil and a new oil filter (the Honda PCX is very good and really not that overpriced). Its all right in your owner's manual. Just keep a log of when you perform the work and with what products you used.
https://www.ahm-ownerlink.com/login.asp?pag...od%5Fhome%2Easp
I log all my stuff right here on the site Honda has made for us; it also makes it very easy to print out for the next owner to see.
Old Feb 13, 2006 | 05:16 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
And keep your bills,to prove you did the oil change.
Old Feb 13, 2006 | 05:20 PM
ppipe's Avatar
With regards to keeping your bills, make sure you keep the bills(receipts)
for the oil you purchased showing the brand,weight and quantity.
Old Feb 13, 2006 | 05:27 PM
Cyclon36's Avatar
Yeah, you'll be fine. Just make sure you pick up the PCX filters from your local dealer or from hardtopguy.com as they are special high flow filters for our car. Most aftermarket ones don't cut it.
Also, make sure you leave in the original oil for the recommended period if you're talking about your first oil change.
Old Feb 13, 2006 | 08:28 PM
MinS2K's Avatar
sorry, but what is the recommended period until the first oil change.
i've checked the oil level and it hasnt changed much but turned brown. i have 2750 mi on my 06 and need to start thinking about oil change pretty soon.
thanks
Old Feb 13, 2006 | 08:34 PM
SenderGreen's Avatar
I think Honda says to leave the factory fill oil in for at least 5000 miles. It may actually be in your owners manual.
Old Feb 14, 2006 | 01:03 AM
RACER's Avatar
3,750 miles or 6 months, whichever comes first.
Personally, I changed mine a little bit early.
