NRG Engine Torque Damper for S2000~
Old Jun 29, 2006 | 05:17 PM
s2k_jay's Avatar
Default NRG Engine Torque Damper for S2000~
im planning to get that torque damper for my S..just want to ask if anybody got it on their car and does it really help from the engine movement?
http://www.S2kAccessories.com/EngineDampers.html
Old Jun 29, 2006 | 06:34 PM
LubedKoala's Avatar
Torque damper or engine damper?
I hear engine dampers reduce engine movement fairly well. Some even claim that their shifting has gotten smoother because of it. I think this is what you are referring to, I don't know what a torque damper is.
Old Jun 29, 2006 | 07:38 PM
gomarlins3's Avatar
I have seen a couple installed, but I don't know how much our car needs it with only 148 lbs of torque.
Old Jun 29, 2006 | 07:50 PM
AJ PwR's Avatar
The engine torque damper reduces engine flex and it will benefit better power transfer to the wheels. You will also notice better shifting as well (more direct shifting feel.)
Old Jun 29, 2006 | 10:08 PM
Aze85's Avatar
i plan on getting one soon and would like to know also. i will probably get it fromben at ajr along with the j's front stb
Old Jun 29, 2006 | 10:20 PM
importkid's Avatar
its said to remove the vibration in the shift knob during driving also (if this rattles or just bothers you that it moves a little)
Old Jun 29, 2006 | 10:26 PM
Aze85's Avatar
i just searched and read through a couple of threads and it seemed like there is mounting/fitment issue with the J's ETD. if you get the etd alone with out the J's stb the fitment is not great. however, if you get the J's stb and the etd together it will mount better, but might rub against an A/C line.
also, does anyone know if you need to drill through the stock heat shield for this to fit?
Old Jun 29, 2006 | 10:29 PM
importkid's Avatar
drilling will be needed.
Old Jun 29, 2006 | 10:31 PM
importkid's Avatar
double post...
Old Jun 29, 2006 | 10:37 PM
Aze85's Avatar
dang. i know if i try it i will end up drilling a few holes.
