NRG Engine Torque Damper for S2000~
Originally Posted by JDM S2000,Jun 30 2006, 03:50 PM
Isnt there a revised one that doesnt need drilling?
There is a revision being made right now on the NRG ETD that will include a place to secure the fuse box onto the ETD bracket, like the J's. There are modifications required to make the ETD work and fit.
Drilling? Yes you need to drill a hole in your stock heat shield...or remove it for the dampner to fit...and you need to remove the welded fuse box bracket...so yes you need to drill (or remove the stock heat sheild) and then remove the stock fuse box bracket both NRG and J's.
No drilling for me. I just used the J's Heatshield. Only the small bracket that holds the fuse box must be removed. Pretty easy this one, I removed it with my hand moving it up-down and then just filed the edges to make them smooth.
yea most likely
