NYS emmissions fail?
Old Jun 19, 2017 | 12:01 PM
gerry100's Avatar
Default NYS emmissions fail?
I keep a tender on my battery over the winter mainly so I wont lose the emission codes.
Didn't work this year and my 06 failed the emissions part of the inspection.
My battery is at least 6 years old and is weakening, could this be the cause?
( minor PITA, I've just got to drive some miles and bring it back for the sticker)
Old Jun 20, 2017 | 12:04 PM
Car Analogy's Avatar
It sounds like your readiness monitors weren't all set yet. As you already know, a few driving cycles will set them all.
If you get an obd reader, it will tell you the status of these readiness monitors, so next time you'd know if they would fail you for this. It'll also be useful to read codes and reset them, on any modern car.
You can get a simple one for less than $50. There are also versions that work with your smartphone, some much cheaper than that.
Unless your battery dies to the point of needing a jump or is disconnected, your readiness monitors aren't going to be erased. A weak battery won't reset them. Once your battery is charged, they'll set as you drive and stay set unless voltage drops below a threshold (which is way lower than the point at which battery will be too weak to start the car).
Old Jun 20, 2017 | 03:12 PM
gerry100's Avatar
Thanks, tender definitely lit up all winter and she fired right up
However , I may have run it down last summer from sitting and needed to hook up
the charger. Not sure
Old Jun 23, 2017 | 07:02 AM
gerry100's Avatar
drove another 80 miles around town and brought it back to the garage and had it checked with there scanner, Two OK, two yet to reset.
He suggested a stretch of highway 60-70 mph driving and that the tank was still 3/4 full and maybe the evaporative canister not cleared yet.
Still not sure why this is happening but I'll keep the forum posted
Old Jun 26, 2017 | 01:15 PM
gerry100's Avatar
another 110 miles with a highway cruise and Cat, evap system still not reset.
Guy at garage said he's got a car with 500miles still waiting for the codes to clear.
Old Jun 27, 2017 | 11:16 AM
Langelo DeMysterioso's Avatar
Drove for a week before I was able to get them jokers reset. About 200 miles
Old Jul 21, 2017 | 09:06 AM
gerry100's Avatar
up tp 320 miles and the Cat and evap haven't reset yet.
Called Honda dealer and they have nothing useful to offer.
Drive on I guess
Old Jul 21, 2017 | 09:16 AM
cosmomiller's Avatar
Top Answer: 1
Billman is knowledgeable on the exact cycle that needs to be performed to reset it. Not sure where the threads live.
Old Jul 22, 2017 | 09:08 PM
HarryD's Avatar
Originally Posted by Billman250
There is no mileage quota for any car ever made to make the ECU "ready" (meaning complete all monotors).
It goes by parameters, and them being met. Can happen in 3 miles, or over 200.
In some cars, conditions are picky and they will take over 150 miles to make ready. Basically, you are meeting the enable criteria on accident if you are not following the exact enable criteria, for that car, for EACH parameter (or monitor).
Lucky for us, the s2k monitors complete very fast, I have done it in 6 miles.
Fastest way:
Start the car cold in the morning, drive around local 5 minutes, shut it off (this will complete a "trip").
Start it back up, take it on the highway and set the cruise at 60 for 3 minutes (this will complete a second "trip", and make two-trip monitors "ready" like the air pump monitor).
Example: if you start the car cold, and drive it 10,000 miles without shutting it off, the two-trip monitors will never run and you will fail inspection It's all about parameters...not miles.
From: https://www.s2ki.com/forums/s2000-un.../#post21838123
Also:
Monitor will run easiest with a half tank. That's your problem. Do not fill up.
In NY, 2001 and newer cars can pass with one incomplete monitor. 1996-2000 can have two incomplete monitors and pass.
From: https://www.s2ki.com/forums/s2000-un.../#post23056571
Old Jul 24, 2017 | 06:06 AM
gerry100's Avatar
Thx , will try these tricks next chance I get
