obd newbie plz help
Old Jul 26, 2007 | 01:22 PM
dyhppy's Avatar
Default obd newbie plz help
will these work on our cars to reset the ecu?
http://cgi.ebay.com/ebaymotors/OBD2-OBD-II...sspagenameZWDVW
http://cgi.ebay.com/ebaymotors/Car-Scanner...sspagenameZWDVW
http://cgi.ebay.com/ebaymotors/EQUUS-INNOV...sspagenameZWDVW
if you know of a better deal on one, plz post it.
also, why are some only $15 and some over a couple hundred?
thnx
Old Jul 26, 2007 | 02:41 PM
Johnny Sack's Avatar
you know autozone will reset it for free.
Old Jul 26, 2007 | 02:46 PM
dyhppy's Avatar
i called pepboys and kragen and they wont help me. ill try autozone. thnx
Old Jul 26, 2007 | 03:33 PM
__redruM's Avatar
Doesn't pulling the battery cable or the fuse also reset the ECU? You don't need special tools to pull the battery cable for 30 seconds.
Old Jul 26, 2007 | 03:41 PM
Project22a's Avatar
I don't know if this works on the s2k, but pulling the clock/radio fuse on my prelude for 30 seconds resets the ecu.
Old Jul 26, 2007 | 03:57 PM
tof's Avatar
tof
+1 on pullng the negative cable off the battery for 30 seconds. BUT, be sure you have the code for your OEM audio system before you do. Otherwise you won't be able to use the radio or cd until you visit the dealer and perhaps pay them to pull the head unit and get the info they need to retrieve the code.
The reason for the high cost of the equus scanner is that it is a much more feature rich scanner...it probably displays text identifying the meaning of the code as well as just the numeric codes. It can also read and interpret manufacturer specific codes. There are other features as well that they describe in the ebay ad.
Clearing the code is one thing. Knowing why you are getting it is another. The generic cheap-o readers are fine as long as you have a table to show what the code means in an S2000.
Old Jul 26, 2007 | 04:05 PM
dyhppy's Avatar
unpluggin the battery doesn't work
Old Jul 26, 2007 | 04:06 PM
CKit's Avatar
Can't you just pull the backup fuse from under the dash? It's the second fuse in on the top row. Not worth it to buy an OBD II scanner just to reset the CEL, IMHO. If you want to tell what code was thrown, then go for it.
Otherwise just pull the fuse for 30 seconds. And you don't need to reset your radio.
Old Jul 26, 2007 | 06:01 PM
CKit's Avatar
I tried to make this as idiot proof as possible.
Use a good flashlight or shop light and it'll make life easier.
Pull for 30 seconds. Put it back. CEL gone. Car will idle a little oddly after resetting the ECU as it'll "learn" timing again. That's normal.
And I personally wouldn't clear a CEL without knowing what it was.
And don't mind all the extra wires and connectors....
Old Jul 26, 2007 | 07:13 PM
dhayner's Avatar
CKit is right.
