Occasionaly 2nd gear grind?
Old Sep 8, 2002 | 01:26 PM
s22k's Avatar
my car does exactly the same thing as TTsupra's. i am afraid to redline it in first gear because of this problem.
Old Sep 8, 2002 | 03:12 PM
TTSUPRA's Avatar
[QUOTE]Originally posted by s22k
[B]my car does exactly the same thing as TTsupra's.
Old Sep 8, 2002 | 04:14 PM
schwantz's Avatar
I guess I'm fortunate that my tranny does not have this problem. It must vary from car to car.
Old Sep 8, 2002 | 07:58 PM
boiler's Avatar
Originally posted by TTSUPRA
i guess its wroth a try to switch tranny fluid to the GM synchromesh stuff but is it to early to change i have 4k miles only
How close to the floor does your clutch start to engage? If it's pretty close to the floor, and I suspect that it is, then it is extremely important to floor the clutch when shifting. Otherwise, you're shifting while under power and will surely cause the transmission to grind.
I don't think that it's too early too change your transmission fluid. I was reading about a Tremec transmission breakin procedure and they only said to break it in for 15 minutes. BTW, I changed mine at 18,000 miles and it looked new, still.
Old Sep 8, 2002 | 09:09 PM
SEVNT4's Avatar
junehhan, I noticed mine doing the same exact thing! I have an 02 bought in July and with the clutch fully depressed, it will either have a notchy feeling or even an actual slight grind. Only on two occasions did I miss a shift from 1 - 2 and it is annoying as hell not to mention nerve racking.
Originally posted by junehhan
My clutch pedal is completely to the floor when I shift. I have tried taking every bit of human error out, but it still seems to do it occasionally. Something I have noticed, is that the faster I slam the shifter into 2nd gear, the less likely it is to grind it going into 2nd. If i've been idling at a light for a while, or i'm facing uphill, it will also slightly grind 1st gear going in from neutral as well.
Old Sep 9, 2002 | 02:45 PM
TTSUPRA's Avatar
yea my clutch catches really low i hope that it is human error i'll pay attention for the next few days and redline 1st and see what happens.
thanx fior the replies
Old Sep 9, 2002 | 03:23 PM
jelliotlevy's Avatar
No 1-2 gear grind whatever with my '02 @6200miles. There is a subtle notchiness in the 2-3 shift that occurs most of the time - that has been there since the beginning, but it never shows up as a metallic grinding.
Old Sep 9, 2002 | 06:27 PM
s2ksimon's Avatar
GM Syncromesh Transmission Fluid ??
GM tranny oil into a Honda ? I'm a little hesistant in doing so. Are there any better brands ?
More importantly, what is the "Zaino" of transmission fluid ?
Thanks
sj2000
Old Sep 10, 2002 | 03:27 PM
boiler's Avatar
[QUOTE]Originally posted by sj2000
[B]GM Syncromesh Transmission Fluid ??
Old Sep 10, 2002 | 08:46 PM
RedHead's Avatar
I'm trying out the theory of moving the seat forward. So far, I have done about 10 1 - 2 shifts @8000 rpm with zero grind. I'll give you guys an update later.
