OEM Cat
Old Jan 16, 2008 | 03:25 PM
s.hasan546's Avatar
Default OEM Cat
How hard is it to take off the OEM cat? could i do this myself? im thinking about geting the berks high flow cat.
Old Jan 16, 2008 | 04:07 PM
daktruckie99's Avatar
With your 07 it should be a piece of cake because your bolts are new.
It simply bolts in, so remove the bolts and out it falls.
It can get to be a PITA on older cars because of severely rusted bolts, but you should be fine
Old Jan 16, 2008 | 04:12 PM
ScubaDivin's Avatar
Well if you have the Invidia V3 its a 70mm pipe and you don't want to choke it down with berk's 63mm test pipe. Go with invidia's 70mm test pipe, thats what im running.
Colton
Emil St-Hilaire's Avatar
Active Streak: 30 Days
...3 bolts in the front,and 2 in the back...+ take care of the O2 sensor...
Old Jan 16, 2008 | 07:15 PM
RedY2KS2k's Avatar
We don't know if you can do it yourself; we don't even know if you can walk and chew gum at the same time.
Old Jan 16, 2008 | 07:20 PM
CKit's Avatar
Easy to do. Make sure you have jack stands so the car doesn't fall on you.
Old Jan 16, 2008 | 07:57 PM
s.hasan546's Avatar
and im geting berks high flow cat not a test tipe
Old Jan 16, 2008 | 08:26 PM
SDredrider's Avatar
^^^ Good idea. I have a Berk's hi flow cat on my 07 and pretty happy with it.
Old Jan 17, 2008 | 07:53 AM
rpmhigh's Avatar
I installed a cat on my S2k but the cel light came out because now is ready a high amount of carbon. Is there a way to clear that light out without reseting the computer, takin the light out etc
Old Jan 17, 2008 | 07:53 PM
chuhsi's Avatar
PB Blaster is a MUST. spray liberally once..let sit for a few hours...spray again. Then undo bolts.
BlueTeg
Apr 30, 2017 10:15 PM
s2konroids
Sep 9, 2013 10:26 PM
scutrCR
Feb 20, 2009 02:50 PM
wampa
Mar 7, 2007 06:59 AM
faukengenius
Oct 11, 2004 07:57 PM
