OEM Exhaust/Test Pipe
Tried to search but couldn't find much on this topic...
With a Comptech intake already installed, what gains would I expect to see (if any) in replacing the OEM cat w/ a test pipe using the OEM exhaust? I'd drop in a VAFC and get the car tuned as well.
Thanks in advance
Paul
Thanks in advance
Paul
you would get negative 5 hp because you're a retard.
J/K
i think you should go get your car dynoed right now without any of the stuff. after that slap on the intake and test pipe, then see what you put down on the dyno with a little bit of tuning.
that way you see the actual increase you're getting.
J/K
The increase you get will be noise on the dyno. The VAFC will get you the gain since you are a MY01.
Save yourself the $2500 fine and remove your middle resonator. That will get the sound you are looking for... and maybe 1hp.
testpipes will get you some decent power. there have been dyno's where they show as much as 8-10hp in high rpms...before anyone calls BS, search for "+T1R +mustang +dyno" and maybe testpipe as well there is a guy who did this and showed great gains.
Although there is an inherent risk of being fined if you get caught...so, its up to you to decide if it is worth it. And no, your not killing more trees
If you are FI, only a test pipe would give you a significant amount. I think the 8-10 is with exhaust as well?
I put a test pipe on for the weight reduction. Easy 10 pounds...
Originally Posted by RWD_RCKT,Jan 16 2006, 04:49 PM
I dyno'd IDENTICAL ( argh ) with just exhaust on my old AP1! And I got a free CEL (before I knew about the mechanical O2 sim)
Originally Posted by Silver9k,Jan 16 2006, 07:50 PM
interesting...was it back-to-back same dyno same day?
Same dyno, different year. : )Just get the test pipe and mash it... but don't forget the 02 simulator!
tsoshi2007
33
Jun 20, 2009 08:05 PM
