OEM lip hardware question
for an AP2 front lip. i bought it used off a member on here with "hardware included" and here is what i got
and this is what i need...apparently
http://www.handa-accessories.com/S2000/s2kfus04.pdf
so how do i make this work...i dont even see the self tapping screws.
this is going to be a headache!
Just installed a lip on my AP2. Pull out the 3 plastic "pins" that are under the existing bumper. Save them. The new lip should have 3 brackets attached to it. Use the 3 bolts in left center of your picture and corresponding nuts to attached the 3 brackets under the front. Hold lip in place and you'll see where the bolts go. Use the self-tapping screws to attached the lip inside the wheels wells. Place the 3 "pins" back in the holes they came out of. - Your done.
which ones are the self tapping. the only ones i see are the 2 huge ones. and i wouldnt even consider them self tapping. tahnks guys.
in process of just throwing it together for now!
