OH OH
Old Oct 4, 2006 | 04:42 PM
radtech's Avatar
Default OH OH
When you hit the redline the throttle cuts out. I understand that, but why would it cut out before hitting the redline. What would cause this. It doesn't happen all the time, I just noticed it. I was accelerating in 2nd gear around 7000 rpm and all of the sudden it cut out.
Any Explanations.
Old Oct 4, 2006 | 04:43 PM
K-Lo's Avatar
maybe your car isn't letting you go into vtec? check your oil
Old Oct 4, 2006 | 04:47 PM
radtech's Avatar
Well the Vtec kicks in at 6000rpm, so I think that it's happening after it kicks in.
Old Oct 4, 2006 | 04:55 PM
ian05s2k's Avatar
if it is right after you start the car, then the car wont let you go past 7000 rpm until the car has warmed up sufficiently. You shouldnt be reving it that high though right when you start the car, or at least I wouldnt. If it is not right after you start the car, then i dont know. Hope that helps.
-Ian
Old Oct 4, 2006 | 04:59 PM
Spartikus's Avatar
I've noticed this as well. On really cold mornings even after the car is warmed up it will hit the rev limiter at around 8500rpm instead of ~9k. I just assumed the car doesn't like the cold.
Old Oct 4, 2006 | 05:00 PM
Chazmo's Avatar
No, Ian... I think the thing is that the cold car won't engage VTEC. I would be more concerned about your oil level.
Rad, check your oil level IMMEDIATELY.
Old Oct 4, 2006 | 05:11 PM
ian05s2k's Avatar
Sorry about that. I guess just dopnt pay attention to my first post. ON my AP2, right after I got it, i tried reving it up all of the way and it cut out at 7000 rpm, and when i took it to the dealer to have it checked out, the tech said the car just has to warm up before you can rev it all the way to 8000 rpm and that it was a safety feature toprotect the motor. Could have been full of crap though I guess.
-Ian
Old Oct 4, 2006 | 05:15 PM
Chazmo's Avatar
Hmm.... Well, it's true that you shouldn't hammer the thing until it's fully warmed up. I didn't think the ECU prevented you from redlining, but it's possible. I am certain though that VTEC won't engage.
Old Oct 4, 2006 | 05:16 PM
radtech's Avatar
Thanks, I'll check the oil.
Old Oct 4, 2006 | 05:22 PM
ian05s2k's Avatar
I couldnt tell you for sure since i am getting my info from a tech in Alaska, and since it is Alaska, pretty much everyone is a bunch of red necks, hippies, or people dum enough to want to live here. Once again, sorry if I caused some confusion. Maybe somone can confirm whether or not my theory was correct.
-Ian
