oil catch can
Old Oct 19, 2004 | 01:42 PM
silkshocker's Avatar
Default oil catch can
I tried the search function and it did not work.
Old Oct 19, 2004 | 01:53 PM
Lead_Foot's Avatar
are you talking about an "oil pan"? Those are used for oil changes to empty the old oil into.
Maybe u mean something else though, i never heard of an oil catch can
Old Oct 19, 2004 | 01:55 PM
hahnn002's Avatar
You new guys are confusing the hell out of eachother! Yes there is such a thing, Cusco seems to be the popular brand on the board for it.
rajun asian's Avatar
I was wondering the same thing. If any of the technical gurus are here, please chime in.
Old Oct 19, 2004 | 01:57 PM
pantyraider's Avatar
Seems like a lot of people don't know how to use the search.
If you want to do a search for a specific phrase you have to include quotation marks, ex.: "oil catch can"
Then it will search for that entire phrase. If you just do a search for oil catch can it will most likely give you a bunch of bogus links.
Old Oct 19, 2004 | 01:59 PM
hahnn002's Avatar
search for oil catch can revealed MANY results here is a quote from a post by Naishou:
When a cylinder fires, some oil vapour, water vapour and other gunk is blown past the rings into the crankcase. In the old days this was vented to the air, but it's a pollutant. Nowadays legislation forces car makers to use Positive Crankcase Ventilation (PCV) which uses the pressure in the crankcase caused by blowby to redirect gases via a hose into the inlet, so they get burned again. The hose goes from the top of the valve cover to a place usually just after the throttle body. This is great if you have negative inlet pressure (inlet vacuum), but if you have a forced induction engine, you have a problem when under boost. To prevent inlet charge being blown into the crankcase, there is another connection (via a T-piece or similar) to a point before the turbo. Now when on boost the pressurised air will take this path instead and also create a little bit of vacuum in the part of the hose connected to the valve cover, helping to draw vapour out of the crankcase. The problem with this is that the oil vapour now goes through the intercooler and intake piping, condensing there. You can actually pour oil out of the intercooler on some high pressure turbo cars without a catch can. A catch can is a container that goes in the PCV line to filter and condense the vapour before it ends up in your intake. They are pretty much necessary on high pressure turbo engines, but on a NA engine the only point is to prevent the vapour getting into the cylinders again (it doesn't go into the intake hose on a NA car). This is bad because it reduces performance and effective fuel octane rating. However, unless it's got deliberately loose rings or is making a lot of power per litre, I don't think a NA car really needs one.
Old Oct 19, 2004 | 02:00 PM
hahnn002's Avatar
For those who just dont get it....
This is my understanding of it:
In hard, high G corners (particularly right hand ones with this car) oil can make it's way up through the PCV valve and into the intake manifold where it's burned off once it gets into the cylinder. The solution for this is a catch can which does just that. It stores the oil blowby so the oil does not get into the intake manifold. Do a search for specifics.
Dhaval85
Jan 7, 2013 08:36 AM
sparrow
Mar 30, 2010 10:53 AM
fastD
Feb 28, 2005 08:59 PM
fltsfshr
Dec 2, 2004 04:43 AM
NAP1
Aug 3, 2004 06:30 AM
