Oil consumption for 04s
Old Sep 13, 2004 | 09:51 AM
hpark's Avatar
i follow the severe schedule
Changed oil at 3500 mi and seeing on oil burn for me either
Old Sep 13, 2004 | 10:35 AM
geekd's Avatar
I used 1/2 quart in my first 3750 miles, then got an oil change and diff fluid change.
I'm at 7300 right now, doing my second oil change this week, no usage at all.
I VTEC every day.
-geekd
Old Sep 13, 2004 | 10:45 AM
jchung's Avatar
i changed my oil around 6500 miles and it is around 9000. i just checked my oil and it is at "LOW". interesting.
Old Sep 13, 2004 | 11:04 AM
Cyclon36's Avatar
The dealer also mentioned the "special honda break in oil" to me, but they said to change it out at 4500miles. I switched to Mobil 1 5w30 after that and haven't noticed a bit of consumption even after a weekend at the dragon.
Old Sep 13, 2004 | 11:09 AM
Mark16q's Avatar
I vtec after every meal and before bed. Gone 1000 miles and oil is down maybe 1/4" on the stick. So it is burning a bit so far, but nothing major.
Old Sep 13, 2004 | 11:25 AM
WPS's Avatar
WPS
wanted to add that after that first change i haven't burned a drop and the 2nd is coming up. maybe everything is sitting better, i have no idea. using mobil oil currently. probably switch to synthetic at 15k and do every 5k.
Old Sep 13, 2004 | 11:41 AM
CrazyPhuD's Avatar
So there actually is a break-in oil and it has been discussed quite heavily in the RR oil journals.
I'm also one who has experienced no oil burning.
Old Sep 13, 2004 | 12:25 PM
124Spider's Avatar
My dealer, even knowing that I do my own oil changes, said that, unless the car is driven as a weekend driver by a grandmother who drives gently, you should follow the severe schedule. Several guys there said that changing out the break-in oil is correct at 3750. They also said, several times, that one should not change to synthetic oils until 10,000 miles, since some break-in continues for 10,000 miles, and synthetic oils apparently don't allow that remaining break-in to take place. I'm following that advice; I changed at 4000 and 7800 miles, and will start using synthetic at about 10,000 miles.
No detectable oil use yet.
Old Sep 13, 2004 | 12:35 PM
yulook's Avatar
I just changed mine yesterday and i have about 6500 miles. I bought Castrol syn 10-30 at costco for around 20 bucks. My friend who helped me bought Mobil 1 syn. It's sooooo clear you can't even tell you have oil.
Until i changed it, i never had any problems oil oil consumptions.
Mark
Old Sep 13, 2004 | 12:53 PM
WPS's Avatar
WPS
Mark
i have that same problem with the regular mobil. right after an oil change it's hard to read the stick til it browns out in a couple hundred miles.
