Only Have Valet Key. Can I Cut a Master?
Originally Posted by anamono' timestamp='1370584617' post='22592409
[quote name='dwight' timestamp='1370583293' post='22592393']
If the dealer ordered the wrong part then they'd have to deal with unloading a $130 key, not you.
[/quote]
Yeah, it does.
Do you have a high-security valet key or standard chip key?
The speciality key is high-security and can ONLY be used in this type of door/ignition.
The dealership will use you VIN to get the key code. then give it to a key vendor who will cut it. Youll need to use a bigger name company for the key cut/program if you are infact using a high srcurity key.
I use Hi-Tech national quite often.
Good luck.
Good luck.
Good luck.
Good luck.
