Opera Performance S2000
Old Jul 10, 2006 | 03:14 PM
Will's Avatar
Lookie Lookie what I found...
guess this is old news!!!
https://www.s2ki.com/forums/index.php?showtopic=126013
Also, the swiss cheese holes they drilled throughout the car decrease weight while adding to the structural rigidity; pretty cool concept... see, every hole isn't just a hole--the edge is beveled inward. If you have a flat piece of sheetmetal, you can twist it, using torsion (I think), rather easily. Drilling a hole adds to the problem because there is less material to resist the force against it. But beveling the edge of the hole makes the hole rigid, causing the metal to have to bend AROUND the hole, which is much more difficult to do. This makes the metal more resistant to twisting than before the hole was drilled.
maybe "beveling" isnt' the right word... but I hope you can visualize this... the hole's edge is bent inward.
Old Jul 10, 2006 | 05:14 PM
Wildncrazy's Avatar
Also in a lot of the places you see holes that is 2 layers of metal. Instead of reinventing the wheel for stiffeners, in a lot of places they simply bought another factory piece and welded it on top of the piece already there.
Old Jul 10, 2006 | 05:27 PM
Harpoon's Avatar
What's amazing is that with all that work the ASM car still beats it in time attack.
The engine was actually heavily modified, but still NA. ITB's, custom exhaust, AEM ECU, etc.
Old Jul 10, 2006 | 05:45 PM
felixs2k's Avatar
Opera does exist; they are a very small company located in Japan. Due to their size, it's probably why most people give us clueless stares when we talk about Opera.
Old Jul 10, 2006 | 05:50 PM
Jakup's Avatar
Originally Posted by kamui157,Jul 10 2006, 01:55 PM
Google doesn't even yield results. I heard end weight came out to around 2300lbs...
Actually it ended up being 2167 after they were done (although they exagerate it by saying the car started out at 2967 or something, which is almost 150 pounds over what the S2K weighs).
Amazing car, not a ton of horsepower (~275 at the flywheel) but they said it laps Tsukuba around 1'01.00
Old Jul 10, 2006 | 06:15 PM
ness1216's Avatar
They only did that on the RSX featured in the magazine, not to the s2000.
Old Jul 10, 2006 | 06:59 PM
Vapor's Avatar
That's incorrect. Material was added to the S2000 as well.
And the beveling is called chamfering.
Old Jul 11, 2006 | 04:38 PM
mrluckys's Avatar
opera also prepared the asm car so the chassis is likely to be similar.
Old Jul 11, 2006 | 07:55 PM
Jakup's Avatar
Not to mentione ASM is a widebody and claims over 300hp (crank) opposed to Opera's 270hp.
jhp012
Sep 27, 2007 06:39 PM
THEOLDMAN
Oct 5, 2005 03:22 PM
jon305
Jan 20, 2004 11:51 AM
Partshelper
May 30, 2002 03:18 PM
Rasputin314
Jul 12, 2001 09:34 AM
