Optimal launch?
Old Jul 21, 2001 | 03:00 PM
carfanatic's Avatar
Default Optimal launch?
What have you guys found to be the best method for a speedy (sub 6 second) launch? How high do you rev?
Old Jul 21, 2001 | 06:01 PM
Penforhire's Avatar
It must be my size (big boy here) because I read lots of posts saying 3-4K shocks their rear loose. I have to go at 6.5K or higher to be certain of a smile. Maybe my pavement grips better?
Old Jul 21, 2001 | 09:51 PM
carfanatic's Avatar
It usually takes at least 5K for me to squeal the rear wheels.
Old Jul 22, 2001 | 02:47 AM
DavidM's Avatar
It totally depends on the conditions. You need to take all this into account:
- weather
- temperature
- how new/warm the rear tyres are.
- what kind of surface you're on and how much grip it has.
- how much have you got loaded in your car
There's even more variances, but look at it this way. When it was warm here (summer/spring) - I needed 7k+ revs in order to keep the wheels spinning though the pre-vtec revs (bellow 6k). 7.5k were the optimal revs. On the other hand, now it's winter and on a dry road, I can break the rear wheels with about 3k - 4k revs. I've even done it on one cold night with about 2.5k revs.
So as you can see, you really need to try it for yourlef as there's way too many variables. Though, you're better starting wiht higher revs than loower as you're better spinning the wheels too much than shocking the drive train.
Old Jul 22, 2001 | 09:38 AM
YoungS2K's Avatar
7.5K is a little high for me. I races every weekend, the usual launch rpm are 6200-6600 rpm range. Just try it out. If it bog when the tires stop spinning try to launch it a little higher next time. If you spins left/right lower the launch rpm.
Old Jul 22, 2001 | 10:15 AM
Sev's Avatar
Sev
- weather
- temperature
I believe you forgot to mention the most important factor of the bunch. Tire pressures. At 38 psi, i can spin all day with a 6k drop. at 32 psi, i would need 7k to do the same...
Old Jul 22, 2001 | 04:26 PM
twohoos's Avatar
Don't forget that SOME wheelspin is needed for a good ET, just not so much that you end up fishtailing or even standing still. They should spin for maybe half a second to a second or so before really hooking up. So the "best" rpm to taunch at is the one that produces that amount of wheelspin, and will vary depending on the conditions. Experiment a little, and remember Sev's advice: tire pressure, tire pressure, tire pressure.
GreenmanS2000
May 13, 2015 10:50 AM
m1bjr
Nov 21, 2009 03:59 AM
PR84
May 12, 2008 01:35 PM
weak_sauce
Apr 23, 2007 08:41 AM
soulcrew
May 11, 2006 12:50 PM
